Old 02-17-2015, 12:42 AM   #1
Hentai
Hentai's Avatar
Drives: 2015 Halo GT86
DRL problem, HELP PLEASE!
So suddenly my right DRL won't work anymore for some reason.
I have a 2015 frs which i just bought barely a month ago.
I checked the fuses and all the connections under my driver seat and everything is still new and intact. My left DRL works.. any suggestions? Or should I just bring it back to my dealership and let them handle it?
Thanks guys
Hentai is offline   Reply With Quote
Old 02-17-2015, 01:00 AM   #2
jonzhuxD
Drives: Ultramarine FR-S
Maybe your high beam bulb is burnt out, try switching the bulbs and see if your right DRL is working. Unless you're talking about dealer/aftermarket installed DRL then I have no clue.
jonzhuxD is offline   Reply With Quote
Old 02-17-2015, 01:03 AM   #3
Hentai
Hentai's Avatar
Yes, I've tried switching the Bulbs to LED's and the Stocks, I also used the bulb from the left highbeam headlight to the right, and it still won't work... Really frustrating :/
Old 02-17-2015, 01:04 AM   #4
jonzhuxD
Do both of your high beams work?
Old 02-17-2015, 01:07 AM   #5
Hentai
Hentai's Avatar
No, my left highbeam bulb is 100% fine, works as a DRL also.
My right highbeam bulb does not work at all.
Old 02-17-2015, 01:17 AM   #6
jonzhuxD
I would check the high beam bulb socket, maybe there's a bent pin or similar preventing a connection to your bulbs. If you have one you could check the voltage at the high beam connection with a multimeter.
Old 02-17-2015, 01:20 AM   #7
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Just go dealer and have them fix it... ?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 02-17-2015, 01:35 AM   #8
Hentai
Hentai's Avatar
Tried checking on it.. No reads, maybe something came off to make the connection not go through, sigh. Might just need to go to the dealer and let them take a look at it.
Old 02-17-2015, 01:43 AM   #9
jonzhuxD
At this point the dealer is probably your best option, keep us updated on what happens!
Old 02-17-2015, 02:34 AM   #10
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
Did you install aftermarket LED bulbs for DRL's? And then the problem started? I'm wondering if that's the issue. I'd be interested in finding out what the outcome of your situation is. Keep us posted.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-19-2015, 04:54 PM   #11
tachi1247
tachi1247's Avatar
Drives: 04 BMW 330i & 03 Mazdaspeed Protege
I'd switch the bulbs back to stock before taking it to the dealer....
tachi1247 is offline   Reply With Quote
Big Problem jpit Engine, Exhaust, Transmission 156 05-13-2014 08:21 PM
DRL problem benlaz88 Scion FR-S / Toyota 86 GT86 General Forum 23 09-19-2013 08:58 PM
DDM HID Problem LinknLog Cosmetic Modification (Interior/Exterior/Lighting) 18 04-11-2013 12:43 PM
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
Problem! axss Scion FR-S / Toyota 86 GT86 General Forum 32 11-24-2012 02:31 PM
