Drives: 2014 BRZ MT (Sold); 2006 V70R
Factory amp connector adapter?
Here's a thought that I haven't seen before. Maybe someone mentioned it, but I haven't seen it yet.
I believe the factor unit for the BRZ (not sure about FRS), runs a full spectrum signal to the trunk, where the factory amp sits. The amp then filters the input, and sends a low pass signal to the front door woofers. Is this correct? My though for a simple/easy/unobtrusive audio upgrade is simply replace stock amp w/ a small 2ch amp around 50wx2 utilizing factory wiring, and upgrading the front door speakers to a set of full range 2-ways. The main "problem" here of course, would be finding a 2ch amp that would fit in the stock amp location, and an adapter to utilize the stock amp connectors w/o splicing up the factory wires. Anyone know if this is possible and where to get these adapters?
'14 BRZ LTD MT DGM
Drives: White 2014 Scion FRS
+1 on this, I would love to do this instead of opting for the OEM Audio+ option.
Drives: FRS
http://www.ft86club.com/forums/showthread.php?t=42239
Ktp-445u is bridgable into 2 ch.
| DIY: BlackVue DR500GW-HD Car Cam w/Power Magic Pro Using Factory Option Connector | ChiefG | DIY (Do-It-Yourself) Guides | 42 | 11-28-2017 12:04 AM |
| ECM Pin Connector | simpleisbest | Software Tuning | 19 | 01-18-2015 02:13 AM |
| What's this connector ? | mashal | Electronics | Audio | NAV | Infotainment | 5 | 12-10-2013 01:13 AM |
| Help, what connector is this? | Hayashi | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-26-2013 01:39 AM |
| VSS Connector | AlexTheGreek | Engine, Exhaust, Transmission | 15 | 02-02-2013 12:12 PM |
