Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 02-04-2015, 02:19 PM   #1
Desi Gt86
Drives: 2014 Toyota 86- Crystal White Pearl
Drop in air filter opinions pls!!!
Hi all,
Considering an aftermarket air filter. My car is stock standard but after 10 000kms looking for a bit more without voiding warranty.
Any suggestions?
Any advice would be appreciated.
Thanks,
Desi
Desi Gt86 is offline   Reply With Quote
Old 02-04-2015, 02:23 PM   #2
STV3
Señor Member
STV3's Avatar
You are welcome
http://www.ft86club.com/forums/showthread.php?t=13245
Now learn how to use Google!
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
LauraDUP (02-05-2015)
Old 02-04-2015, 02:23 PM   #3
bigred18
MJLONIR Program Member
bigred18's Avatar
Drives: 2014 Scion FR-S
Originally Posted by Desi Gt86 View Post
Hi all,
Any suggestions?
Thanks,
Desi
K&N drop in filter. I'm looking for one myself for an easy 5ish hp. It's an easy swap and a good filter to have if you have a stock intake.
ドラゴンに乗る
Instagram: Komodo_Actual
My car build: http://www.ft86club.com/forums/showthread.php?t=81094
bigred18 is offline   Reply With Quote
Old 02-04-2015, 02:24 PM   #4
swarb
Oiled or non-oiled.
pick a color.
impossible to void warranty.
I went with afe dry.
Search.
Old 02-04-2015, 02:39 PM   #5
BRY100
BRY100's Avatar
Drives: GT-86 High Spec MT Silver
I put in a K&N filter last Sunday. Lets be honest, you aren't really going to notice massive gains with 5HP more, however, my car does pull ever so slightly stronger now.
The K&N filter is much thinner than the cotton wool looking stock filter, so the engine is definitely breathing easier.
BRY100 is offline   Reply With Quote
The Following User Says Thank You to BRY100 For This Useful Post:
Desi Gt86 (02-04-2015)
Old 02-04-2015, 03:57 PM   #6
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
K&N would be best value for money in South Africa,
You can get this at ATS in Randburg, Gauteng. (Not sure about CPT and DBN options) (When purchased mine I paid around R800 (Cannot remember exactly)
http://www.ats-motorsport.co.za/
There are a few Vendors in the US that keep them, but specific vendor shipping costs vary, also consider the import duties etc....Im sure shipping it will cost less than ATS, But if you dont want to wait and deal with the hassle of shipping etc ATS is the way to go...
If anyone else has knowledge of Drop In Filters in SA, please share,
If you going the 'import way':
Here is a screenshot of my personal spreadsheet filtered for K&N DIF and the Blitz DIF. (These have estimated prices)
(Theres no 'price check' apps for mods have to do it manually)
You should check on www.ebay.com and www.amazon.com as well
Hope it helps,
FT_86_SM_GP is offline   Reply With Quote
The Following 2 Users Say Thank You to FT_86_SM_GP For This Useful Post:
Desi Gt86 (02-04-2015), LauraDUP (02-05-2015)
Old 02-04-2015, 10:52 PM   #7
Desi Gt86
Thumbs up
Thanks BRY100 and FT 86 SM GP
Was leaning towards the k&n. Understand it's not going to be massive gains but would like to see a slight improvement.
Appreciate the feedback.
Old 02-05-2015, 12:10 AM   #8
Dammod
Dammod's Avatar
Drives: .
Hey @Desi Gt86,
Welcome to the forums
We have noticed a very slight bump in airflow when using an AFE and K&N drop-in filter.
Remember that the results you see for tests done internationally will probably show a higher hp/kw gained then what we should experience here on our fuel assuming the tests were done on the required octane for the 86 there and 95 Pump fuel here, however it still gives you an idea as to which flows better.
Due to the extra airflow from a drop-in filter, it will cause the car to run a little leaner which will usually result in more power, however a leaner car is more octane dependent for pre-detonation prevention.
As @FT_86_SM_GP said, the K&N will be your best bang for buck. We have found its airflow increase to be similar to that of a AFE filter.
Another advantage, and probably he biggest, is that drop-in filters are usually washable. This means that instead of waiting 30000-45000km (which is far to long for our local conditions IMO) for your filter to be replaced by the dealer, you can wash your filter say every 10000km and simply swap back to stock when its time for a service.
"Some will follow your footsteps, easier than they will your advice."
Dammod is offline   Reply With Quote
The Following User Says Thank You to Dammod For This Useful Post:
Desi Gt86 (02-05-2015)
Old 02-05-2015, 12:45 AM   #9
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Originally Posted by swarb View Post
Oiled or non-oiled.
pick a color.
Search.
ROTFLOL!!!
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 02-05-2015, 01:17 AM   #10
BRY100
BRY100's Avatar
Price check - K&N cost me R910 last week at ATS.
Old 02-05-2015, 01:19 AM   #11
FR-STEEL
Drives: Steel FR-S
Is HKS an oiled filter or dry? Couldn't find clarification through threads or description of product!
FR-STEEL is offline   Reply With Quote
Old 02-05-2015, 02:40 AM   #12
sav
sav's Avatar
HKS is usually dry foam but I could be wrong. I like the Afe dry filters.
95RON SAV Tuned
Old 02-05-2015, 02:41 AM   #13
sav
sav's Avatar
http://www.hks-power.co.jp/en/produc...ter/index.html
"Joining of each layer was changed from flame lamination to net type joining that does not affect intake air flow. Dry 3 layer structure enables lower resistanc"
95RON SAV Tuned
Old 02-05-2015, 04:26 AM   #14
Desi Gt86
Thanks Dammod,
The Following User Says Thank You to Desi Gt86 For This Useful Post:
Dammod (02-05-2015)
FS: K&N Drop In Filter Vides990 NY / NJ / CT / PA 10 07-23-2014 01:11 PM
Trd drop in filter Vino Engine, Exhaust, Bolt-Ons 3 04-14-2013 11:08 AM
FS: K&N Drop-in Filter DookDookDGM Engine, Exhaust, Bolt-Ons 4 01-19-2013 01:45 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 02:40 PM
