Old 01-30-2015, 03:29 PM   #1
Jonsey
Jonsey's Avatar
Track Suspension Settings
I thought it would be helpful for everyone if we could compile a list of suspension settings people have found works well for them on the track. I am open to any suggestions, but I think the following format would be a good place to start. I thought it would also be helpful to list your suspension components.
Settings:
Front Camber:
Front Caster:
Front Toe:
Rear Camber:
Rear Toe:
Suspension Components:
Springs and rates:
Shock/coilover type:
Front sway bar:
Rear sway bar:
Endlinks:
Bushings:
Front Camber devices:
Rear camber devices:
Wheels:
Tires:
Aero:
Notes:
(neutral, oversteer/understeer, allows good turn in, etc.)
Jonsey is offline   Reply With Quote
Old 01-30-2015, 03:32 PM   #2
There are like a gazillion permutations...
You'd also need to add in tire model/size, wheel model/size, aero, etc....
Jonsey (01-30-2015), zdr93523 (02-08-2015)
Old 01-30-2015, 03:33 PM   #3
Jonsey
Jonsey's Avatar
Settings:
Front Camber: -3.0
Front Caster: Stock
Front Toe: 0.0
Rear Camber: -1.9 (will change to -2.5 when rear LCA installed)
Rear Toe: 0
Springs and rates: Swift Spec R (Front 4.4kg, rear 5.3kg)
Shock/coilover type: Koni Yellow
Front sway bar: Perrin 19mm
Rear sway bar: Perrin 16mm
Endlinks: SPL (rear)
Bushings: diff inserts, rear subframe inserts
Front Camber devices: Raceseng camber plates
Rear camber devices: None (SPL LCAs to be installed soon)
Wheels: OZ Alleggerita 17 x 8
Tires: Bridgestone Potenze RE-11a 225/45/17
Aero: Driveway Labs Type 1 rear diffuser
Notes:
Car is neutral with slight oversteer tendencies. Turn in is slightly slow
Old 02-01-2015, 12:47 PM   #4
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
my latest set up, car feels slightly understeer if Apex too late, will keep this setting until CSG Spec Tein SRC shows up
Settings:
Front Camber:-3
Front Caster:-7
Front Toe:0
Rear Camber:-3
Rear Toe:0
Springs and rates: Swift R
Shock/coilover type: OEM
Front sway bar: OEM
Rear sway bar: OEM
Endlinks: SPL Pro
Bushings: SPL Pro spherical
Front Camber devices: RaceSeng
Rear camber devices: SPL Pro LCA
Wheels: RPF1 17x8 +35
Tires: AD08R 225/45/17
Aero: Varis Arising II front lip, TRD side fins, Rocket Bunny side skirt, OEM full underpanels, Voltex Type2 wang
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 02-01-2015, 02:34 PM   #5
kster1
kster1's Avatar
Car feels fairly neutral but getting some push on low speed corners; I suspect this is driver induced and I need to follow-up by examining my data. Some tire temps are linked here but I need to get off the track sooner so they aren't cooled off as much:
http://ImageEvent.com/kster1/cars/brz/tiretemps
Settings:
Front Camber: -2.7
Front Caster: not adjustable
Front Toe: 0
Rear Camber: -1.8
Rear Toe: 0
Springs and rates: Eibach 350 front/425 rear
Shock/coilover type: Ohlins R&T
Front sway bar: OEM
Rear sway bar: OEM
Endlinks: OEM
Bushings: OEM
Front Camber devices: Ohlins camber plates
Rear camber devices: RacerX LCA
Wheels: TC105N 17x9 +35
Tires: 235/40/17 RA1
Aero: FT-86 race splitter, Voltex 1S rear wing
kster1 is offline   Reply With Quote
The Following User Says Thank You to kster1 For This Useful Post:
RehabJeff86 (02-02-2015)
Old 02-08-2015, 02:16 AM   #6
brn12345
brn12345's Avatar
Settings:
Front Camber: -2.5
Front Caster: stock
Front Toe: 0
Rear Camber: -2.0
Rear Toe: 0
Springs and rates: KW Clubsport
Shock/coilover type: KW Clubsport
Front sway bar: Stock
Rear sway bar: Stock
Endlinks: Perrin and Whiteline
Bushings: Stock
Front Camber devices: KW Clubsport
Rear camber devices: SPC lower arm
Wheels: Wedsport TC-105N 17x8 42+
Tires: Dunlop Direzza II Star Spec (for autocross 29psi F/ 31psi R, roadcourse 24psi F/ 26psi R)
Aero: STI rear lip spoiler
front end hooks in corner entry, mid, and exit
rear end hooks in corner entry, looser mid and exit
The Dunlops are much faster than the Rivals I had before but the car feels wobbly as opposed to solid with the Rivals. The Dunlops are good for 1.5sec on the road race track.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 02-08-2015, 10:36 PM   #7
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Settings:
Front Camber: -3.1
Front Caster: 6.8
Front Toe: 0
Rear Camber: -2.7
Rear Toe: 0
Springs and rates: RCE Yellow
Front sway bar: Eibach (soft)
Rear sway bar: Eibach (soft)
Endlinks: OEM
Bushings: OEM
Front Camber devices: HVT Top Hats, SPC Camber Bolts
Rear camber devices: SPC LCAs
Wheels: RPF1 17x8 +45
Tires: Maxxis RC1 225/45R17 (39psi hot)
Aero: FT-86 SpeedFactory Race Splitter, Driveway Labs Type 1 Rear Diffuser
Notes:
Neutral and fast. Handles imperfections/bumps with ease. Perfectly even tire temps indicates alignment and tire pressure are completely dialed in. Tons of grip with the RC1s.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 02-08-2015, 11:55 PM   #8
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
2.2 -2.5 was plenty of camber for me
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
Bilstein B16 settings for street/AX/track dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-10-2014 04:16 AM
Track suspension advice ddeflyer Tracking / Autocross / HPDE / Drifting 138 05-29-2014 06:35 PM
Suspension settings for different size tires Pokeguyjai Tracking / Autocross / HPDE / Drifting 2 01-24-2014 03:44 PM
Suspension for Auto-X v. Track.... How different? mtimney Tracking / Autocross / HPDE / Drifting 3 08-20-2013 02:18 PM
