Old 01-24-2014, 02:05 PM   #1
Pokeguyjai
Pokeguyjai's Avatar
Drives: 2013 GBS BRZ (AT)
Suspension settings for different size tires
Hi Guys,
My current setup for my suspension is RCE Yellows Springs with Koni Yellow dampers. I also have two different sizes of wheels. My track tires are 225/45/17 17x8 RPF1s and my street tires are 245/35/18s 18x9.5 TC105ns.
The Koni Yellows only have a firmness adjustment. Would it be a good idea to adjust it every time I switched wheels? (I plan to do at least 5 track days for this upcoming season)
If I did bother to find the best settings, would there be a drastic difference between two optimal settings for the two different size wheels?
Thanks!
Pokeguyjai is offline   Reply With Quote
Old 01-24-2014, 02:21 PM   #2
SubiePig
Drives: -'02 PSM WRX, '94 Miata, '13 BRZ
Find what works on the track setup and leave them at that. If you don't like the ride on those settings, count the number of notches on the knob(since they don't have clicks) you pass when setting them from full hard to what you track them on, write it down and find what is comfortable for the street. Do not run yellows on dead soft, though.
Sponsered by:Chasebays/Corr Performance Tuning/KartBoy/Bad Panda Motorsports/Racer-X Fabrication
STX Build thread 14th/67 SCCA Nationals (2014)
SubiePig is offline   Reply With Quote
Old 01-24-2014, 03:44 PM   #3
Pokeguyjai
Pokeguyjai's Avatar
With my butt dyno, how will it feel if it is too soft?
tires size - 225/50/18 AE86_Mikko Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-27-2013 09:44 AM
Help with suspension/tire size combination... Kuzuri Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-14-2013 06:26 PM
Anyone running 225/45/17 tires? How do you like that size so far? Chimpo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-01-2012 02:24 PM
Think all tires of the same size ARE the same size? Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 09-26-2012 08:41 PM
What size tires should I get for 19s? mrha Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 12:23 AM
