Old 01-20-2015, 07:09 PM   #1
Mr Kirmudget
Mr Kirmudget's Avatar
Drives: 2013 Ultramarine FRS
Random traction control and ABS lights?
So there I was driving home when all of the sudden the traction control and ABS lights turned on. When I parked I turned the car off and started it again and the lights were gone. I'm not too concerned about it, I just want to make sure it isn't a precursor to nuclear holocaust or something of the sort.
Mr Kirmudget is offline   Reply With Quote
Old 01-20-2015, 07:49 PM   #2
Shit Skynet!!!!!
Nah they are probably fine if they went back off. Sometimes the sensors pick up a weird signal.
If they come on and stay on or the cargoes into limp mode (low RPMs only and just limps along) then you may have a problem.
If it keeps happening then get it checked out, otherwise don't panic (unless of course you see a terminator behind you).
2much (01-28-2015)
Old 01-20-2015, 07:50 PM   #3
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
This may sound stupid but, I found that when I rested my hand on the console
I would at times actuate the switch turning off the TC /ABS. Once I figured that out, the "problem" went away. Maybe that's the issue you're having...???
Caspeed is offline   Reply With Quote
Old 01-20-2015, 08:21 PM   #4
AllStar0419
AllStar0419's Avatar
Drives: 2013 FR-S Asphalt
Have you done any mods related to your break lights? I installed a 4th break light and those lights came on for me until I changed the ground location.
Sent from my XT1254 using Tapatalk
AllStar0419 is offline   Reply With Quote
Old 01-20-2015, 08:37 PM   #5
Midarete
Midarete's Avatar
Drives: Whiteout FRS
I have been having ABS/Trac lights as well, also have the rear fog light (triangle) wired up to the driver's side taillight. Can you tell me where did you ground the rear fog instead?
Midarete is offline   Reply With Quote
Old 01-20-2015, 08:51 PM   #6
Mr Kirmudget
That was my first thought but I pressed the button and nothing happened.
Just installing new taillights, but that hardly counts.
Old 01-21-2015, 05:59 PM   #7
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
I turn traction off all the time, and have never had an ABS light.
I thought the only way to get ABS off was to do the pedal dance. Even with traction "off" it's still on.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 01-21-2015, 06:06 PM   #8
Caspeed
Caspeed's Avatar
Correction VSC/SPORT lights. My bad
Old 01-27-2015, 08:00 PM   #9
AllStar0419
I originally had it grounded to the taillight bolt farthest to the drivers side. I changed it to the other taillight bolt closer to the center of the car and made sure I sanded the area really well so it was hitting bare metal. No issues since.
When I did have the problem, the third brake light in the rear window was staying on all the time too.
Old 01-27-2015, 08:06 PM   #10
AllStar0419
Some people in this thread had the problem with just taillights
http://www.ft86club.com/forums/showthread.php?t=11509
Old 01-27-2015, 08:41 PM   #11
qqqqball
qqqqball's Avatar
Wheel speed sensor...You hit anything recently? Have you replaced the suspension? replaced brakes? Change your wheel bearings? Have you come in contact with the wire at any point in time...Make sure the speed sensor is connected tightly.
I had this issue...but I bought my car totaled and rebuilt it so that was the least of my concerns!
qqqqball is offline   Reply With Quote
Old 01-28-2015, 10:01 AM   #12
paulca
Drives: Toyota GT86 Coupe Red (UK)
Shit Skynet!!!!!
Already here dude.
[ame="http://en.wikipedia.org/wiki/Skynet_%28satellite%29"]Skynet (satellite) - Wikipedia, the free encyclopedia[/ame]
Yes, in their ultimate wisdom (or humour) the British Ministry of Defense decided to call their satelite network "Skynet". In fairness, I believe they were launched long before the movie was made.
No joke!
Trunk = Boot | Hood = Bonnet | Sidewalk = Pavement | Transmission = Gearbox | Stick/shifter = Gear knob/stick | E-brake = handbrake | Windshield = Windscreen | Turn signal = Indicator
paulca is offline   Reply With Quote
The Following User Says Thank You to paulca For This Useful Post:
Tcoat (01-28-2015)
Old 01-28-2015, 10:08 AM   #13
Originally Posted by paulca View Post
Already here dude.
No joke!
Old 01-28-2015, 11:36 AM   #14
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
I just had this happen to me the other day! No lighting related mods :P
Just turned the car off & back on and then the lights went off. I think my car is trying to tell me to fill up on E85...
Yeah...that's definitely it. I shall obey its request.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
How to disable Traction Control (TC) and Vehicle Stability Control (VSC) Completely Sigh-on-Rice DIY (Do-It-Yourself) Guides 58 03-02-2015 01:48 PM
traction control and abs lights coming on after 20mins? UnLeasHer AUSTRALIA 28 02-23-2015 09:52 AM
CEL/Traction Control Lights artizhay Issues | Warranty | Recalls / TSB 5 11-04-2012 10:33 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
