ACE Headers
Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Issues | Warranty | Recalls / TSB
Old 07-13-2012, 11:31 AM   #1
G86
Drives: 2012 Grey GT 86
Issues - Traction control and ABS warning light on
Hi there,
I've just picked up my manual 86 a week ago. I'm in the midst of still running the vehicle in. Today I've switch it on after work and instantly both the ABS and Traction Control light come on....
I've tried switching it on and off multiple times, but the lights still appear.
Anyone had these issues or come across them??
G86 is offline   Reply With Quote
Old 07-13-2012, 11:35 AM   #2
Kwaziekeller
Kwaziekeller's Avatar
Drives: '13 Argento MT FR-S
Sounds like there is a problem with ABS/TCS and I'd get it to a dealer ASAP. Could be an issue with the systems themselves. You could try to disconnect the battery for a while and reset the ECU to see if it goes away but I'd want to get it looked at. In the meantime, you're probably left without ABS/TCS/Stability.
Kwaziekeller is offline   Reply With Quote
Old 07-13-2012, 11:38 AM   #3
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Did you turn the car on and off completely?
Snoopyalien24 is offline   Reply With Quote
Old 07-14-2012, 04:46 AM   #4
G86
I'd turned the car off and then back on multiple times, with no luck.
I disconnected and then reconnected the battery and lights still appeared. At no point have they flickered or changed. They've been solid since.
I've logged an issue with the dealership. Now waiting on a response.
Old 07-14-2012, 04:49 AM   #5
Shinji2787
Shinji2787's Avatar
Drives: '85 AE86 Sprinter Trueno
Wait.... are you implying that the traction controls are off by default...? Because they are not....
Shinji2787 is offline   Reply With Quote
Old 07-14-2012, 05:04 AM   #6
#87
I usually post drunk
#87's Avatar
No, if there is an issue the lights are on in the dash because the ECU turns them off...... Because it does that...
#87 is offline   Reply With Quote
Old 07-14-2012, 09:41 AM   #7
G86
Correct.
So for some weird reason the traction control and abs lights are on and can't be switched off, which obviously is the ecu telling you there's something wrong.
Since then I've also discovered that the cruise control function does not work at all.
The car is driving fine... I've just lost all the electronic driver aids.
I'm hoping a reset of the ecu or a diagnostics test should pin/solve the problem. Fingers crossed.
Old 07-14-2012, 10:49 AM   #8
MTeator
First 86
faulty abs sensor perhaps.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 07-14-2012, 11:33 AM   #9
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
There are multiple issues that could cause this. Take the car to the dealer, they will be able to check what is causing the lights to illuminate and fix it (likely under warranty).
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 07-22-2012, 01:06 AM   #10
UnLeasHer
UnLeasHer's Avatar
Drives: Toyota 86 GTS & Mazda 3 SP23
Originally Posted by G86 View Post
Hi there,
omg same issue! with cruise control off and everything! have u fixed it?
UnLeasHer is offline   Reply With Quote
Old 07-22-2012, 09:51 PM   #11
UnLeasHer
UnLeasHer's Avatar
Took the little one to the service center.
The guys down there said there was nothing wrong with the computer, and everything was fine.
They think that having the traction and abs notification on in the driving conditions I was in (wet, lots of corners, higher speeds) was normal, and that the car pre-selected this driving option (i.e. also turning off cruise control and options for other drive types (i.e. traction off, sports VSC (and for those with GTS 'sports' and 'snow')).
If this happens to you - the notifications coming on means that the car is letting you know (additional?) traction and ABS is ON - it does not mean that there is a fault to be checked. After the driving conditions improve, and you have turned the car off for 1 min and back on the car should take these notifications off. If not, then there might be something wrong.
I said that I did not noticed any different handling but they said it couldve been such a tiny change that I did not notice the difference (which is most likely true being asian, young and female LOL).
Car is a.o.k and smarter than I thought.
My 3 <3's - husby, kitty and 86sy... depending on the road/ traffic conditions they may not be listed in order of preference.
The Following User Says Thank You to UnLeasHer For This Useful Post:
Bonburner (07-22-2012)
Old 07-22-2012, 10:44 PM   #12
Subie
Seņor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I'm sorry but you were fed a bunch of baloney. The ABS and traction control lights come on to indicate a fault in the system. The cruise control wasn't working due to the same fault; either a wheel speed sensor or some other component was not functioning properly and triggered those lights. If the lights went off on their own the fault was temporary, and the next time the car did a self-check everything was working properly and therefore the lights did not come back on.
Subie is offline   Reply With Quote
The Following 8 Users Say Thank You to Subie For This Useful Post:
andrew20195 (06-05-2014), Bristecom (04-22-2014), John Rambo (02-15-2016), Kakawate (02-15-2014), R2RO (08-08-2018), raptor87 (04-23-2014), Toyota GT 86 (08-15-2014), Wilso (05-27-2014)
Old 07-23-2012, 01:28 AM   #13
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I think the OP meant that the lights came on when the car was turned on. From a cold(ish) start, I don't see how it would be the same as if you were on a wet road, it sensed it, and this happened.
I've driven in the rain plenty and never seen it come on and stay on. I'd say something is definitely wrong. There was another member who had this come on and stay on, got rough idle, and then had check engine codes related to crankshaft sensors. Not to make you paranoid, but I would definitely take it in if you start the car and get those lights staying on.
eriktherod is offline   Reply With Quote
Old 07-23-2012, 08:14 AM   #14
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
I had the same issues as well
Tt3Sheppard is offline   Reply With Quote
Search this Thread:
Advanced Search
Traction/VSC Setting Preference ashtray Subaru BRZ General Forum 27 08-24-2018 03:39 PM
TPMS warning light **New Info** sdiver68 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 10-11-2012 07:25 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
traction control issue *KID* Scion FR-S / Toyota 86 GT86 General Forum 13 07-08-2012 08:13 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R Subaru BRZ General Forum 40 04-25-2012 11:20 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
