Northern California NorCal
Old 01-07-2015, 12:47 AM   #1
sid325
Drives: Ultramarine FR-S 6MT
ECU/flash update
I bought my FRS in January 2013, late 2012 build, never been back to the dealer... But, I've read I may benefit/need an ECU update? Yes/no? Any Bay Area dealers worth a damn or somewhere/someone else that could update for me?
Thanks.
sid325 is offline   Reply With Quote
Old 01-07-2015, 01:03 AM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Thanks.
There is no tab in the US so no dealer will perform a reflash. There is speculation that there was a change in Jan 2013 but there is no way to confirm it. Tunes from ecutek and oft use the most recent OEM flashes so that is the best way
Old 01-07-2015, 01:07 AM   #3
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Couldn't hurt to check. ECU flashes are pretty straight forward, so any dealer should be able to do it. Keep in mind, for some reason it took my dealer (Livermore Subaru) a couple hours for the ECU TSB update. They said it would only take 30 mins, I was pissed...
Old 01-07-2015, 01:24 AM   #4
sid325
Ok, that helps. I've been looking at doing a tune but thought a flash from the dealer first would be beneficial. Looks like a tune will do it all. Thanks.
Old 01-07-2015, 01:13 PM   #5
strat61caster
strat61caster's Avatar
You're in the same bucket as me, 12/12 build date and I'm 99% sure that we have the outdated tune that was blamed for the injector seals melting. I only found confirmation on the updated tune on 03/13 built cars and definitely outdated on 11/12 built cars, in between is a bit of a black hole.
http://www.ft86club.com/forums/showthread.php?t=41130
Don't freak out and think the sky is falling, there are maybe at most a couple hundred people who were affected out of the 30,000+ units sold with the original tune and many have abused their cars with no issues (myself included).
To the point of the thread, are there any standout service departments in the Bay Area? I'm finally looking for the reflash too (otherwise leaning towards OFT) and I need a coil pack replaced. Also have condensated taillights but I can let that one slide.
Edit: In theory any dealership should do it, one that I called up was all gung-ho "Sure bring it in! It'll be a 2-3 hour appointment" sounded like the kind of place that I'd go to pick my car up from and have a $600 bill attached to what should have been free warranty work...
Old 01-07-2015, 01:36 PM   #6
Rosaki
Rosaki's Avatar
Drives: 2013 SWP BRZ
This may be different but the result was what you were asking.
I had my car misfire and run on 3 cylinders at 3k miles for some reason. I took it back to where I bought it (Livermore Subaru) and they said that a new tune was available and that the reflash should fix the issue. By the time they saw it, the car was running fine and there was no cel or data they could pull. They didn't ask anything about proof or anything else from there on. I believe my car was a 6/2013 build and they flashed it with a new tune. (also replaced pealing steering wheel and cricket pump at same time)
Maybe that would work as an in? I haven't had any issues with Livermore service personally but others may have...
Also, I believe (at least I think...) any obd2 reader can tell what OEM map you are using. Feel free to come out to a southbay meet and ill see what I can read with mine if your in the area!
2013 SWP BRZ
---JRSC, JR Oil Cooler, Ohlins, TC105N 17x9, 245 RS3, JDL CBE, SPL PRO, Whiteline
2002 LS2 V8 Miata (Sold)
2000 BMW Z3 M Coupe (Sold)
Rosaki is offline   Reply With Quote
Old 01-07-2015, 02:49 PM   #7
PMok
Codename: Stitch
PMok's Avatar
mine was a mid-2012 build, bought in Oct 2012 and I had the older (900C) tune. Newer cars have A01C, B01C, etc. which purportedly include the fix for the injector seals. 900C did not.
When I brought it in to Livermore Subaru last year and asked for the newer flash, they took it in, addressed some other warranty issues (including cricket/fuel pump), but when I got the car back they said no new flash is available for your car.
So my solution was to buy and use OFT to get the fix that the dealership wouldn't give me. Don't regret it at all since the OFT also brings other improvements you won't get from a factory reflash.
Old 01-07-2015, 03:29 PM   #8
finch1750
finch1750's Avatar
Can Torque read the version? I got my ecu replaced in Feb 2014 and want to check
Old 01-07-2015, 04:10 PM   #9
Rosaki
Rosaki's Avatar
I believe it can. If I remember correctly, that's what I used last time to view it. I think its in the adapter status section... ill try to check tonight.
2013 SWP BRZ
Old 01-08-2015, 12:31 AM   #10
sid325
Good info, thanks all. Concord and Walnut Creek Toyota are worthless... I'm stock except for intake and exhaust. I'm just looking for a reliable smooth safe DD tune. Anyone been to Works for tuning?
Old 01-08-2015, 03:57 AM   #11
finch1750
finch1750's Avatar
Not sure how many have been to Works for a tune. I know there are a couple guys running tunes from EQ, a bunch on OFT, a couple on Delicous tunes from when he comes up to Mann Engineering, and then a few running/have run e-tunes from James @ HRI.
Old 01-08-2015, 05:40 AM   #12
steve99
Torque app will read calibration id from ECU
For USA/canada guys any calid earlier then ZA1JA01C manual or ZA1JA01D auto ie 700C 900C A00C (or D) revisions don't have DI seal fix (transient ignition retard enabled).
B00C and B01D were idle stability fixes when A/C switched in/out
I believe their is a TSB to flash older cars to B01C/D
D00C/D is for My2015 cars only.
11-136-14_Idle_Stability.pdf
S-SB-0040-13-RPM Drop.pdf
for all TSB see here
www.ft86club.com/forums/showpost.php?p=548473&postcount=1
or just do it yourself with Tactrix/ecuflash see link below, stock rom their as well
www.ft86club.com/forums/showthread.php?t=62332
most tunes will bump you to latest compatable rom for car as well as tune changes.
Old 01-10-2015, 07:19 PM   #13
finch1750
finch1750's Avatar
When I check the calibration ID under adapter atatus it only says ZA1 without giving me the full reading. I am very curious as I have a early production model but had my ecu replaced in Feb 2013.
Old 01-10-2015, 08:04 PM   #14
steve99
Thats weird seems like some problem with torque app or adapter, try changinf some of the communication or adapter settings , think their are some speed and compatability options.
update torrque app ??? does it read other data ok
WARNING/HELP! ecu bricked from ECUtek Latest update/flash Dream20b Software Tuning 14 09-14-2014 08:07 AM
a little update :) ilpad Northwest 15 06-12-2014 06:36 AM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Open Flash Tablet Manager Software (problem after internet update) SloS14 Software Tuning 6 10-31-2013 03:33 PM
Litchfield BRZ & GT86 Recall flash update Litchfield Engine, Exhaust, Transmission 2 11-24-2012 07:02 AM
