Y u do dis?
WARNING/HELP! ecu bricked from ECUtek Latest update/flash
So i'm sitting at a local shop getting work done to my car. The work gets finished so I decide to flash to the newest base map I have sitting on my laptop.
I haven't updated my files prior in a while, so I figured now was as good a time as any to update. I updated my file, built the new software and all that stuff. Next, I went to detect my ECU, found the ECU as normal. Went to flash the ECU like I normally would and the screen freezes for a minute then tells me my ECU is "part programmed" and that I may have to have it flashed. Tried to flash it again but the port is not readable now and the car won't start. It will turn all the Idiot lights on and the radio works, but the car won't start. What do I do?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
Drives: 2013 FRS Asphalt
Did you update the software prior to flashing. There was software update maybe a month or two ago that caused this issue. It was supposed to be fixed.
2013 Scion FR-S AT Picked up 5/30/2012
Y u do dis?
Yes
Dat Hot Lava Doe
Y u do dis?
Dat Hot Lava Doe
Drives: for the sake of driving
Were you getting work done at touge? Im here right now and there is a hot lava parked out front. Hope you get it figured out!
'13 Argento FR-S
#6 | |
Y u do dis?
Yep, that's my car.
Dat Hot Lava Doe
I'll keep it company, so it's not sitting put there by itself haha
On a serious note, I haven't reflashed my car in a while, so I'm not sure what the deal with the new update is, but I'm guessing you guys tried pulling the battery cable to reset the ecu?
'13 Argento FR-S
Y u do dis?
no, I didn't try that
Dat Hot Lava Doe
#9 | |
I Love custom Turbo kits
Drives: Limited BRZ
#10 |
Drives: '13 10 Series FRS #1203
UNless the ECU gets completely shorted out, you should be able to flash it even if a flash fails right?
#11 |
could be a number of things.
if it says part ptogrammed it likely failed part way through flash. unfortunatly with cutek it stores part of your licence info in the rom of the ecu. with any flashing device it erases ecu first then writes new rom. it likely your ecutek licience info in rom is lost and you will now need your tuner or ecutek to renew your licience. the concern is also why the first flash failed main causes will be damaged cable or odb socket in car or low or flat battery in car or other electrical systems active during flash ie turn off everything in car radio fans ect. |
#12 |
Drives: UK GT86
Turn car off, turn car back on, manually select vehicle (not auto detect) in ECUtek, continue as normal. As it's part programmed it cannot detect the ROM type so it will warn you upon manual selecting about flashing an incorrect ROM.
.: Stealth 86 :.
#13 | |
Y u do dis?
Tried this but it just freezes up.
Dat Hot Lava Doe
#14 |
Y u do dis?
I'll hear back from the master tuner at some point today. I'll keep you guys posted. So far I've had an email back requesting my log file.
Dat Hot Lava Doe
| EcuTek Flash finished but now it shows only a Partial Flash... | Cross | Software Tuning | 32 | 02-12-2014 10:55 AM |
| I think I bricked my ECU with EcuTek help | iketiak | Engine, Exhaust, Transmission | 4 | 07-03-2013 11:19 PM |
| Anyone had success with iOS 6 latest update? | camelflage | Electronics | Audio | NAV | Infotainment | 2 | 11-08-2012 11:32 PM |
| CEL returns after latest re flash | STEVEOSTI | Issues | Warranty | Recalls / TSB | 15 | 10-05-2012 11:26 AM |
