Wind Noise
Did a quick search and didn't come up with anything meaningful. The amount of wind noise that seems to be coming from the area around the triangle window/side mirror at highway speeds is starting to really bug me. Has anyone had the problem and solved it? Seems to me that a car with a .29 CD should have little to no wind noise.
#2 | |
![]() You might treat the rubber weather stripping with a shot of silicone spray to see if it would limber it up and snug up to the window glass a bit tighter ..... ![]() humfrz |
Drives: 2015 Asphalt FR-S
The seals around the triangle window aren't the greatest, I get a rattling sound right around it.
Drives: BRZ DGM Limited
Since this is a frameless window design wind noise is almost a given. I have reduced it by tucking black weather stripping behind the rubber seals on the car to give then more thickness so that they make a closer contact to the glass.
Drives: 2019 BMW ///M4
Play your music louder.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Drives: 2013 Ultramarine FR-S
I have wind noise as well, but I also get nice cold winter air coming from that area.
#7 | |
![]() That's been the solution so far
Turns out that I have the window seal problem. After I get in if I run my fingers on the inside of the strip and pull it down the noise nearly goes away. Looks like another thing to add to the list for the next time the car goes to the dealer.
#9 | |
Elite Recognized Geek
Drives: 2014 DGM BRZ Limited
I still have the "normal" wind noise from the frameless window design (my first car with those), but it seems much less excessive.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+ |
#10 |
Drives: 2017 86
What type of weather stripping did you use? Rubber or Foam? Thickness? I would like to try this and have some thick foam weather stripping around but would guess it's too thick, unless the factory seal is able to keep it compressed.
#11 |
Drives: 2017 86
Has anyone installed rain guards/ window visors and noticed a decrease in wind noise at highway speeds?
#12 |
not playing cards
Assuming all relevant parts are healthy, the window adjustment is critical. There's precious little slop factor with these things and they're a bitch to get just right.
#13 |
Drives: 2013 FRS
Been the solution for me as well.
As fun as the car is, it kinda beats you up on long drives. Quite a bit of wind/road noise when cruising at 80mph. Turn the music up louder to drown it out. 3 hours later, stop for gas, and it feels like your head is spinning when all the noises goes from 100 --> 0 in a hurry. Can't wait to install my catless UEL header! I'll save the non-resonated front pipe install for when I'm having my quarter-life "I went to college but can't find a job" crisis and need to feel pain to know I can still feel anything at all Ugh...My driver's window is really tight in the middle and I'm dreading popping off the door panel to tinker with it |
#14 |
not playing cards
Probably preaching to the choir but I'll mention the importance of marking reference points and keeping track of each change.
| Wind/road noise at highway speeds? | Kieranz | BRZ First-Gen (2012+) — General Topics | 20 | 06-13-2013 10:11 AM |
| anyone notice excessive wind noise from windows? | BRZnut | BRZ First-Gen (2012+) — General Topics | 18 | 06-11-2013 06:14 PM |
| Wind noise from door seal - possible fix | nzer | Issues | Warranty | Recalls / TSB | 2 | 05-05-2013 02:36 PM |
| In the wind? | joesem | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 01-31-2013 09:09 AM |
| Wind noise at 65 mph? | Siamtampa | Scion FR-S / Toyota 86 GT86 General Forum | 33 | 07-31-2012 01:47 AM |
