Old 01-30-2013, 08:48 AM   #1
joesem
Drives: 97 Civic Coupe
In the wind?
Hey guys! I am just a prospective buyer of a FR-S/BRZ and wanted to know if any of you notice any changes in your car's performance in high winds? My current car is about 100 lbs lighter than the FR-S and it is horrible in any wind; the car goes all over the road. Just wondering if it would be as noticeable in a FR-S with what I would assume has better aerodynamics or what have you. Thanks for any replies!
joesem is offline   Reply With Quote
Old 01-30-2013, 08:59 AM   #2
Cajun
Cajun's Avatar
Drives: asphalt fr-s AT
It was incredibly windy here yesterday, and I never noticed a thing.
Cajun is offline   Reply With Quote
Old 01-30-2013, 09:04 AM   #3
HunterGreene
Hail Magnet
HunterGreene's Avatar
If I had to guess, your 97 Civic is lighter, but higher off the ground and with a higher center of gravity. The twins are much lower to the ground, and provide a much smaller wind profile. I would say you are much less likely to feel wind gusts in the twins, but that is just an educated guess. Has to do with the side profile of the car as well.
Old 01-30-2013, 09:11 AM   #4
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
I'd say that I've had two totally different experiences in my BRZ… The first wind I encountered I felt like it was really getting blown around; however, ever since then it seems to cut through wind like a knife! My guess is that one time the wind gave me issues it was hitting the car just right to do so. I’ll also add that even though the wind upset the car some, it wasn’t drastic enough to be scary. Just noticeable!
Subaru STI :
Old 01-30-2013, 09:14 AM   #5
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Occasionally I notice the wind but it's not enough to be scary or anything.
rapidcars is offline   Reply With Quote
Old 01-30-2013, 09:36 AM   #6
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
DO NOT DRIVE IN THE WIND! this car will start to fly into outer space and crash on the moon! You don't want that to happen!
chenshuo is offline   Reply With Quote
Old 01-30-2013, 09:49 AM   #7
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
My BRZ moves around a bit in crosswinds but nothing excessive. I've driven far worse, like the current generation Corolla, which tap-dances all over the highway if someone so much as farts in a passing car.
Subie is offline   Reply With Quote
Old 01-30-2013, 10:00 AM   #8
gily25
Drives: Silica BRZ 6MT
Either I need more coffee or that was freakin' hysterical...
Don't worry about wind, it's not enough to be a problem...
gily25 is offline   Reply With Quote
Old 01-30-2013, 10:05 AM   #9
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
My worst experience was when high winds were directly blowing perpendicular to me. It was pretty much a little nudge every now and then, definitely much better than my previous car (an Accord). Otherwise, perfectly planted. I have a feeling high speeds and tires also effect it too.
Books is offline   Reply With Quote
Old 01-30-2013, 10:10 AM   #10
FRiSson
Drives: FR-S MT
Not me, I got the optional pivoting exhaust thruster option.
FRiSson is offline   Reply With Quote
Old 01-30-2013, 10:25 AM   #11
sega_102
Drives: Scion FR-S
I haven't noticed the wind at all when driving.
With that said, my other car is a Cube...
sega_102 is offline   Reply With Quote
Old 01-30-2013, 10:34 AM   #12
whaap
whaap's Avatar
After owning a VW Vanagon (bus) for many years, a long time ago, I don't concern myself with cross winds in my low slung FR-S.
whaap is offline   Reply With Quote
Old 01-30-2013, 10:40 AM   #13
strat61caster
strat61caster's Avatar
Much less noticeable than in my truck, much lower, much grippier. I've had winds try to make me change lanes before, not in this thing. You do have to be more alert than something less sensitive though, more aware of what you're doing to the wheel.
The wind definitely hits my mpg meter by 3-4.
Old 01-30-2013, 10:52 AM   #14
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Wind has not been a big deal, but I come from the xB which was a damn wind sail. I will say becareful of grooved roads, they pull the car around worse than any other car I have driven.
5hairpins is offline   Reply With Quote
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
Strong wind killed my door... frs Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 11-24-2012 11:24 AM
Wind Damaged BRZ's thermobox BRZ First-Gen (2012+) — General Topics 6 08-25-2012 10:25 AM
Wind damaged BRZ's thermobox Scion FR-S / Toyota 86 GT86 General Forum 2 08-24-2012 04:23 PM
Wind noise at 65 mph? Siamtampa Scion FR-S / Toyota 86 GT86 General Forum 33 07-31-2012 01:47 AM
