Old 01-04-2015, 04:34 PM   #1
gravitylover
Wind Noise
Did a quick search and didn't come up with anything meaningful. The amount of wind noise that seems to be coming from the area around the triangle window/side mirror at highway speeds is starting to really bug me. Has anyone had the problem and solved it? Seems to me that a car with a .29 CD should have little to no wind noise.
Old 01-04-2015, 05:32 PM   #2
Well now, I haven't noticed any wind noise in my FRS ...... but, I don't hear high pitched sounds anymore .....
You might treat the rubber weather stripping with a shot of silicone spray to see if it would limber it up and snug up to the window glass a bit tighter .....
Old 01-04-2015, 08:29 PM   #3
V_86
V_86's Avatar
Drives: 2015 Asphalt FR-S
The seals around the triangle window aren't the greatest, I get a rattling sound right around it.
V_86 is offline   Reply With Quote
Old 01-04-2015, 08:54 PM   #4
BRZnut
Drives: BRZ DGM Limited
Since this is a frameless window design wind noise is almost a given. I have reduced it by tucking black weather stripping behind the rubber seals on the car to give then more thickness so that they make a closer contact to the glass.
Old 01-05-2015, 02:17 AM   #5
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Play your music louder.
N1rve
Old 01-05-2015, 10:19 AM   #6
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I have wind noise as well, but I also get nice cold winter air coming from that area.
Old 01-05-2015, 10:17 PM   #7
gravitylover
Hmm I like that idea
That's been the solution so far
Old 01-06-2015, 03:16 PM   #8
gravitylover
Turns out that I have the window seal problem. After I get in if I run my fingers on the inside of the strip and pull it down the noise nearly goes away. Looks like another thing to add to the list for the next time the car goes to the dealer.
Old 01-06-2015, 04:05 PM   #9
codesplice
Elite Recognized Geek
codesplice's Avatar
Drives: 2014 DGM BRZ Limited
I had the wind noise and also a bit of water seepage (particularly noticeable after washing the car - never noticed it in normal rainy conditions). I had my dealer take a look at it when I went in for the 7.5k service. They had to order another seal, but that follow-up visit was under 20 minutes for the install.
I still have the "normal" wind noise from the frameless window design (my first car with those), but it seems much less excessive.
This post is a work of fiction. Names, characters, places, and incidents either are the product of the poster's imagination or are used fictitiously, and any resemblance to actual persons, living or dead, business establishments, events, or locales is entirely coincidental.
G+
codesplice is offline   Reply With Quote
Old 01-02-2020, 04:58 PM   #10
DreamSpeedBRZ
Drives: 2017 86
What type of weather stripping did you use? Rubber or Foam? Thickness? I would like to try this and have some thick foam weather stripping around but would guess it's too thick, unless the factory seal is able to keep it compressed.
DreamSpeedBRZ is offline   Reply With Quote
Old 01-02-2020, 04:58 PM   #11
DreamSpeedBRZ
Drives: 2017 86
Has anyone installed rain guards/ window visors and noticed a decrease in wind noise at highway speeds?
Old 01-02-2020, 05:32 PM   #12
Assuming all relevant parts are healthy, the window adjustment is critical. There's precious little slop factor with these things and they're a bitch to get just right.
Old 01-02-2020, 08:59 PM   #13
Stomachbuzz
Drives: 2013 FRS
Been the solution for me as well.
As fun as the car is, it kinda beats you up on long drives.
Quite a bit of wind/road noise when cruising at 80mph.
Turn the music up louder to drown it out.
3 hours later, stop for gas, and it feels like your head is spinning when all the noises goes from 100 --> 0 in a hurry.
Can't wait to install my catless UEL header!
I'll save the non-resonated front pipe install for when I'm having my quarter-life "I went to college but can't find a job" crisis and need to feel pain to know I can still feel anything at all
Ugh...My driver's window is really tight in the middle and I'm dreading popping off the door panel to tinker with it
Stomachbuzz is offline   Reply With Quote
Old 01-03-2020, 02:15 AM   #14
Probably preaching to the choir but I'll mention the importance of marking reference points and keeping track of each change.
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 10:11 AM
anyone notice excessive wind noise from windows? BRZnut BRZ First-Gen (2012+) — General Topics 18 06-11-2013 06:14 PM
Wind noise from door seal - possible fix nzer Issues | Warranty | Recalls / TSB 2 05-05-2013 02:36 PM
In the wind? joesem Scion FR-S / Toyota 86 GT86 General Forum 27 01-31-2013 09:09 AM
Wind noise at 65 mph? Siamtampa Scion FR-S / Toyota 86 GT86 General Forum 33 07-31-2012 01:47 AM
