Old 01-01-2015, 09:58 AM   #1
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Clutch Switch Bypass
Hey guys,
Curious to see if anyone has bypassed their clutch in to start switch?
I haven't had a chance yet to go under the dash yet to see if it's a single plug connection with both the clutch safety switch & cruise control signal or if they're two separate connectors.
* I have no care for cruise control functions, and am doing this for the longevity of my engine, and have owned many factory cars without a css coming from Japan. Also, my car is RARELY parked in gear. I'll write that prior to people start attempting to flame because OMG YOU'RE CRAZY ITS THERE TO PREVENT US FROM BEING STOOPIIIIDDDD
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 01-01-2015, 10:04 AM   #2
wparsons
wparsons's Avatar
Not sure on your question, but how will bypassing the switch improve the longevity of your engine?
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Ranatsu (01-02-2015)
Old 01-01-2015, 10:10 AM   #3
AJPG
Drives: 22RE, FA20, 4G63
Maybe OmarCG meant that this mod is intended to be use for the time he have his car, as it wouldn't do anything to improve the longevity of the car.
My .02 cents.
Happy new year
AJPG is offline   Reply With Quote
Old 01-01-2015, 10:13 AM   #4
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
2jzgte w/a very aggressive clutch/pressure plate is prone to crank walking eventually due to normal (dry) start and excessive pressure on the crank.
Omar GC
Instagram: 2jzus
Old 01-01-2015, 10:16 AM   #5
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
My .02 cents.
Happy new year
Obviously your 2 cents aren't worth even that lol
Omar GC
Instagram: 2jzus
Old 01-01-2015, 10:28 AM   #6
AJPG
Then I didn't understand what is your intention, but is you be so kind and explain
Old 01-01-2015, 10:42 AM   #7
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
http://www.supraforums.com/forum/sho.../465008?page=1
Do some reading...
Now could you please refrain from making more useless post in this thread.
Omar GC
Instagram: 2jzus
Old 01-01-2015, 10:53 AM   #8
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Hey guys,
There is a button that is depressed when the clutch is out. This is tied to the gear indicator and CC. It's also adjustable along with the clutch pedal. Check here http://www.ft86club.com/forums/showthread.php?t=8040
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
OmarGC (01-01-2015)
Old 01-01-2015, 11:08 AM   #9
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Good stuff... thx. Wondering if this is going to drive my dual ecu stepup crazy if i leave that depressed full time...@Drift&Drag
Omar GC
Instagram: 2jzus
Old 01-01-2015, 11:24 AM   #10
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
The easy way to bypass the clutch would be to use spades at the clutch switch itself (above the clutch pedal - blue connector). This will make the vehicle think the clutch is always engaged (although it isn't).
The proper way would be to use a relay that triggers the clutch switch with the key sense or accessory wire that would close the connection to the switch allowing the vehicle to start without the clutch being pressed.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 01-01-2015, 11:40 AM   #11
rusty959
Drives: DGM BRZ limited
Why not just throw another switch somewhere while leaving the factory one in place? It would be simple to throw it either in parallel or series with the factory one (depending on how the factory one is normally open or normally closed) and then all you would have to do is depress a switch vice the clutch pedal when you start. All factory switch operation would go unchanged.
rusty959 is offline   Reply With Quote
Old 01-01-2015, 12:00 PM   #12
AJPG
Do some reading...
Dude you are funny
What you are try to avoid is a small load at the transverse Bering and the center off the crankshaft, but it is so little load and with outstanding oils of this days Anyway it would repeat at each clutch use...
Should be aware that high performance clutch make more pressure, but again not to be so worried; if that deep in the engine are your thoughts then you should worry about bearings ( Rod, main).
As for the instructional link Lol
Be serious about data that would use as reference
Old 01-01-2015, 04:07 PM   #13
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I just jumped the two pins in the clutch position switch with a wire. I can start without depressing the clutch, and I haven't noticed issues with anything else because of it. I haven't tried cruise control though, I never use it
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
OmarGC (01-01-2015)
Old 01-01-2015, 04:48 PM   #14
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
There's no real issue other than the circuit being permanently closed and a slightly negligible increase on electrical load.
The proper way would be to use a relay in conjunction with the accessory or key sense, preferably accessory, wire at the ignition harness. The relay would trigger only when the key is in and you're trying to start the car otherwise the circuit would remain open (i.e. OEM).
1 solution is 5 mins, the other is about 10.
The Following User Says Thank You to ecko04 For This Useful Post:
OmarGC (01-01-2015)
BRZ Nav Bypass lxsedan CANADA 43 03-30-2015 07:44 AM
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch tanner BRZ First-Gen (2012+) — General Topics 26 06-03-2014 08:24 PM
Push-button start clutch switch mike the snake Engine, Exhaust, Transmission 8 04-14-2014 11:31 PM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-30-2013 11:42 PM
