Old 08-30-2013, 01:06 PM   #1
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Pressing/releasing clutch pedal - audible click sound (not the clutchs switch
Anybody notice this?
There's a click sound that comes and go that started to appear about week four with the car. Can't describe how loud it is but it's definitely a lot lot louder than that other faint click which most likely is the clutch switch (which I believe is used to detect if the clutch is depressed so the car can be started or to turn off the cruise control if it's in use).
This louder click seems to occur around the midpoint of the clutch pedal travel, either being depressed or released. It comes and go.
I'll bring it up when the car goes in for it's first oil change but that won't be anytime in the near future.
tanner is offline   Reply With Quote
Old 08-30-2013, 05:45 PM   #2
Stierzy34
:unamused:
Stierzy34's Avatar
Drives: 2005 WRB STi "Edna"
Would be interesting to see what the dealership says about this with the BRZ.
My 2011 WRX did this same thing. Went on and off but would make a tiny click sound when pushing in or letting out.
Stierzy34 is offline   Reply With Quote
Old 08-30-2013, 09:44 PM   #3
SpectreRT
SpectreRT's Avatar
Drives: Subaru BRZ
I have this noise too, but have not discussed it with the dealer yet. I test-drove a FRS and a BRZ before I purchased and both did this. I figured its normal.
SpectreRT is offline   Reply With Quote
Old 08-30-2013, 10:25 PM   #4
AlanLGuy
Drives: Raven 6 speed Manual FRS
Does this occur only when the clutch is pushed in or released or do you also hear this when letting off and on the throttle quickly? This almost sounds like the CV joint
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
Old 08-31-2013, 05:18 AM   #5
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
I'm having the same issue. I'm asking the dealer on my next service.
Silverfox is offline   Reply With Quote
Old 08-31-2013, 10:29 AM   #6
tanner
This happens regardless of what I'm doing. Actually shifting into another gear. At a stop light and in neutral. Car's off and I'm just pushing/depressing the clutch pedal.
Again, the sound comes and go, it's not consistent but it's occurring around the midpoint of the clutch pedal travel regardless if I'm depressing or releasing the clutch.
Problem is, like any dealer, for them to diagnose the issue the issue needs to be duplicated easily and since this comes and goes, it'll be a difficult one to point out. I guess you could try and record a video with the sound happening and show it to them which may help them to look into it.
Did look at an exploded view of the clutch pedal mechanism, could be anything right now on what's causing that click.
Old 08-31-2013, 10:31 AM   #7
AlanLGuy
Well if its happening when the car is stationary and you are pressing and releasing the clutch pedal then it's definitely not the CV joint.
Old 08-31-2013, 10:34 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
I have this but I don't care. Turn on the radio and
Just sounds like some kind of switch doesn't seem at all like something to be worried about so I don't...
Old 08-31-2013, 11:14 AM   #9
Stierzy34
:unamused:
Stierzy34's Avatar
Hmmm, after reading this thread I made sure I listened closely last night while driving the BRZ. It does the same thing that the WRX did. Maybe I just tuned it out so much I didn't even notice it!
Old 09-19-2013, 01:21 AM   #10
gatorbushmen
Amateur Drifter
gatorbushmen's Avatar
Drives: '13 FRS
Yea I just noticed the sound..... Has anything been figured out?
gatorbushmen is offline   Reply With Quote
Old 09-19-2013, 05:39 PM   #11
dehydratedH2O
Drives: 2014 BRZ Limited DGM
I signed up for these forums just because I've had this problem before (and my BRZ comes in next month ). On my 8th gen Civic, I got these exact noises from the clutch pedal. Apparently, cheaper cars these days use plastic clutch master cylinders that are prone to cracking/breaking. When that happens, the grease in the internal springs/bearings seeps out and causes it to start making noises. The Civic community fixed it by replacing the CMC with a metal one, or filled up the broken ones with white lithium grease as a temporary fix. For those of you with this noise, I'd bet asking your dealer to inspect the CMC will turn up a broken/cracked one and get you a replacement under warranty.
dehydratedH2O is offline   Reply With Quote
Old 09-20-2013, 12:40 AM   #12
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Mine makes a "Zzzzt!" sound when I let out the clutch and get on the gas quickly...
Hope it's normal...
daiheadjai is offline   Reply With Quote
Old 09-20-2013, 01:15 PM   #13
Neekowahhhh
Enthusiast
Neekowahhhh's Avatar
Drives: Crystal Black BRZ Limited
Pretty sure this is normal.. My rsx did the same thing.. So did my xb(yea.. Manual toaster)..
Instagram: Neekowahhhh
Mishimoto Air Induction Hose;K&N High Flow Air Filter;Berk Tech Catless Front Pipe;Invidia N1 Catback Exhaust TT;Matte Bronze XXR 527 17x8.25 ET 25
Neekowahhhh is offline   Reply With Quote
Old 09-20-2013, 11:55 PM   #14
uEih
Drives: CBS Subaru BRZ Limited
I have this too, it sounds like it's coming from the clutch pedal, it's sounds more harsher than a click though. Like a few clicks simultaneously. I was wondering if it was an issue that should be brought up since I'm going to bring it to the dealer soon, I also have crickets.. I don't know if they'll do anything about them though but sounds like I have bad belts.
uEih is offline   Reply With Quote
Clutch pedal springy sound pdreams Issues | Warranty | Recalls / TSB 16 06-01-2015 02:33 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 01:10 AM
noise when releasing clutch/shift resistance abutterman Issues | Warranty | Recalls / TSB 11 07-20-2013 09:23 AM
New Clutch Pedal Stopper -- Bang For The Buck Mod!! 86_ZN6 Interior Parts (Incl. Lighting) 1 04-17-2013 10:26 PM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
