Old 12-21-2014, 12:18 PM   #1
smellslikecurry
Camshaft timing oil control valve assembly - P0013
Yesterday I was driving home and popped a CEL for P0013. I opened the hood and noticed that a wire was dangling torn from the Camshaft timing oil control valve assembly...bank 1 exhaust.
This piece broke off and there is some oil residue on the cover. I haven't touched anything near that area.
Anyone else face a similar issue? Part number for the piece?
Parting out car here
Part Out
smellslikecurry is offline   Reply With Quote
Old 12-21-2014, 09:18 PM   #2
smellslikecurry
Part Out
Old 12-23-2014, 06:31 AM   #3
Dezoris
Dezoris's Avatar
Good write up, those connectors are weak I had reseated mine after a few bumps. But to go through that, pain in ass.
Old 12-23-2014, 07:24 PM   #4
Lonewolf
Lonewolf's Avatar
Drives: Moped
Let the dealer deal with it...who knows what else is going on....
Old 01-18-2016, 01:11 PM   #5
driftking96
Drives: 2014 Scion FR-S, 1998 Honda Accord
Was anybody able to figure out the name of the connector and part number? Mine broke off too and I need to figure whats it called so i can replace it.
EDIT: I figured it out. Camshaft timing oil control valve assembly. Part Number SU00300096.
driftking96 is offline   Reply With Quote
Old 10-28-2016, 02:31 AM   #6
a9entjones
a9entjones's Avatar
Drives: MY13 86GTS
Hi....I have a leaking, bank 2 exhaust oil control valve. I am going to replace the seal myself- just wanting to confirm this is simply an unbolt>replace seals>bolt back on deal? No funny business going behing the valve that I need to be aware of?
a9entjones is offline   Reply With Quote
Old 10-28-2016, 04:57 AM   #7
driftking96
Yea personally I didn't need to worry. BUT my engine block had a hole in it the size of my pinkie and I didn't know if I had any oil in it or not bec I didn't bother to check (you can check my other posts regarding that issue). Which is a stupid way of thinking.
In my experience, going on the assumption that I thought my block was fine, had no hole and had oil, all i did was unscrew the bolts and pry it off with your hands and use a flathead of necessary. Then I oiled up the new one around the outside edges and just dropped it in.
Sent from my ONE A2005 using Tapatalk
Old 10-28-2016, 06:22 AM   #8
a9entjones
a9entjones's Avatar
Drives: MY13 86GTS
Thanks....I figured that would be the case....just like a cam angle sensor, etc.
Old 11-02-2016, 09:53 AM   #9
Andew727
Drives: Scion FR-S
can you explain the symptoms of your car or was it just a light. did the car hunt for idle? hard to drive at low rpm? and was that the only code thrown?
thanks,
Andew727 is offline   Reply With Quote
Camshaft timing oil control valve assembly smellslikecurry Want-To-Buy Requests 11 04-12-2017 04:36 PM
Oil Leak at Camshaft Timing Controler Cal3000 Issues | Warranty | Recalls / TSB 17 10-03-2015 11:38 AM
Camshaft Timing Oil Control Assembly smellslikecurry Engine, Exhaust, Transmission 0 12-21-2014 12:10 AM
Dealership Accuses Variable Valve Timing (VVT) Ajustment shiro Issues | Warranty | Recalls / TSB 48 12-20-2013 10:03 AM
Valve Timing/Computer miss paula Issues | Warranty | Recalls / TSB 3 09-20-2012 03:27 PM
