Drives: '23 BRZ Limited
Has anyone used this rear seat delete kit?
http://www.rearseatdelete.com/FRS-BRZ.html
I looked through some old threads but didn't find any mention of anyone actually purchasing or installing it. Looks good, price is right (that Seibon looks out of place and is horrendously expensive). I don't have kids and we are getting a dog, so I thought this would be a better option than getting fur all in the seats and potentially tearing them up when I have to take him somewhere. I know I could lay the seats down, but I like the look and it drops the weight of the car a touch. |
Drives: 2014 BRZ MT (Sold); 2006 V70R
ABS plastic... I don't think this will bear any load.
'14 BRZ LTD MT DGM
How does the top portion stay in place? and is it movable open/close without tools?
I emailed the guys at rearseatdelete.com, here is the answer I received:
"The weight capacity depends on where you place the weight. It’s strongest in the center over the trans tunnel where it could hold 150 lbs, but out towards the edges it can’t hold as much, so if you can keep your dog in the center, he’d be fine." |
#5 | |
Drives: FR-S 10 #103 AT
I had two dogs with a combined weight of about 150 pounds back there. I took out the divider so they could spread out. I did cheat while the dogs were back there and temporarily put some reinforcement under the leading edge of the seat but they were fine for a two hour trip.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
Drives: Asphalt Scion FR-S
If you are good with wood you can fab up your own rear seat delete. I made one that weighs 12 lbs less than stock (seat bottoms and backs) and can support my weight (~150 lbs). Below are pictures of it installed. The carpeting material I picked up from Pep Boys was nearly identical. It's a little darker initially, but over time as it wears it blends in well. Best part is people think it's stock.
Rear Seat Shelf by jdkane527, on Flickr Rear Seat Shelf by jdkane527, on Flickr Rear Seat Shelf by jdkane527, on Flickr Rear Seat Shelf by jdkane527, on Flickr
Drives: Subaru BRZ Limited
Drives: FRS
Drives: asdasdf
Also looking on info on any plywood or other diy kits. I have a 60 lb and 30 lb dog that apparently are not going to do well with the schrader kit.
#10 |
Your dogs won't easily get into the back seat anyways... You going to remove your partner seat?
'14 BRZ LTD MT DGM
#11 |
#12 |
Driver of FR-S 1467
Drives: 2013 scion frs 001467
#13 | ||
Although, now that I think about it, he got in by going over the passenger seat and hanging a left at the center console. My armrest probably helped out there.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." Last edited by mid_life_crisis; 12-12-2014 at 12:26 PM. |
#14 | |
The only advantage the kit has is that it is split and lifts up to turn the space where the seat bottom was into hidden storage.
| DIY: Shrader Performance Rear Seat Delete Kit & Rear Seat Removal | PoorMansRacing | DIY (Do-It-Yourself) Guides | 98 | 10-10-2023 04:51 PM |
| Rear Seat Delete kit | ender2664 | Cosmetic Modification (Interior/Exterior/Lighting) | 53 | 10-04-2017 02:10 PM |
| Rear seat delete? | s30series | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 11-16-2014 11:13 PM |
| REAR SEAT DELETE SUB BOX | NYCsubaruBRZ | NY / NJ / CT / PA | 19 | 01-28-2014 02:38 AM |
