Old 11-12-2014, 10:52 AM   #1
s30series
Drives: 2015 BRZ Series.Blue
Rear seat delete?
I did a search and didn't find anything....but I've found this:
http://www.rearseatdelete.com/FRS-BRZ.html
Anyone have any experience with this? I know there is a full carbon one but it is insanely expensive. This one is not bad at all.
about 25lbs weight savings....that coupled with smaller battery, better brakes, exhaust upgrades, etc could add to over 100lbs of weight savings. Worth it?
Does anyone have this? How much noisy is the cabin? The package comes with sound deadening material.....hmmmmm
I mean, lets admit it. Unless you have kids the rear seat is like 87.9% useless
s30series is offline   Reply With Quote
Old 11-12-2014, 02:24 PM   #2
toast
Drives: 14 BSP Edelbrock BRZ
For that much money you would think that they could have found a cleaner way to fill the bolt hold for the lower cushion. A square of mismatched carpet and a black plug?!
The seats provide a significant amount of noise protection from the floor. I would imagine road noise goes up quite a bit.
toast is offline   Reply With Quote
Old 11-12-2014, 02:50 PM   #3
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I normally don't fabricate my own stuff, but for $400 shipped, I really think it'd just be easier and more cost-effective to just DIY.
Jyn is offline   Reply With Quote
Old 11-12-2014, 02:53 PM   #4
s30series
I think its just the lighting....
This picture doesn't show a big difference in color (on the right side button). I think thats to access the super squirrel secret storage area
Old 11-12-2014, 06:36 PM   #5
8R6
8R6's Avatar
Drives: FRS
sorta on the pricey side, but then again, for the work required to make that out of ABS plastic, i would charge $400 if i was gonna resell it too. lol
pretty cool tho, imo. i might consider this as our rear seat is completely useless other than for looking like a seat. i like the little secret, but not really secret, area created by using this.
8R6 is offline   Reply With Quote
Old 11-12-2014, 07:55 PM   #6
Model Citizen
Lacking brains
Drives: frz
I made my own with some wood materials and subwoofer fabric around the house.
Roughly cost freefitty.
The design of the rear of this car makes it very easy to make.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 11-12-2014, 08:37 PM   #7
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I have that rear seat delete. It's pretty nice. There is quite a bit of foam built into the rear panel and the seat panels. They are well made and very clean looking. You can't really see the bolt that someone was complaining about.
industrial is offline   Reply With Quote
Old 11-12-2014, 09:12 PM   #8
s30series
How is the noise level in the cabin? Comparable to when the seat was there?
Old 11-13-2014, 07:27 AM   #9
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Not quite but close. There is a huge difference in sound with the little divider up and down. I didn't take any db readings before and after so it's hard to quantify the difference but subjectively, it's the difference between being able to have a conversation at 80mph comfortably and having to yell. I have a jdl uel header, catted nameless op/fp and perrin resonated exhaust.
Old 11-13-2014, 09:32 AM   #10
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Even with kids, it's "fairly" useless. It's honestly a hassle to get one of mine in and out, and even then, he's only been in the car a hand full of times since we have an SUV as the family car.
Wouldn't most of the weight be in the restraint system anyway? If you aren't going to use the back seat for people anyway, it would be free to just remove those from the rear.
slicktop is offline   Reply With Quote
Old 11-13-2014, 10:03 AM   #11
s30series
Yeah I'd imagine the seat belt system weights only like 7 lbs....the rest of those 25lbs comes from the seats themselves.....
Old 11-16-2014, 08:32 PM   #12
ogrowup
Drives: Asphalt build in progress
I imagine if you lined the floor under the back seats and the spare tire well with Dynamat it would make a huge difference. That stuff is amazing. It's pretty expensive but it has a big impact on the comfort/noise level in the cabin...
ogrowup is offline   Reply With Quote
Old 11-16-2014, 11:13 PM   #13
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Id rather spend that $400 on dynamat on the back
DIY: Shrader Performance Rear Seat Delete Kit & Rear Seat Removal PoorMansRacing DIY (Do-It-Yourself) Guides 98 10-10-2023 04:51 PM
Rear Seat Delete kit ender2664 Cosmetic Modification (Interior/Exterior/Lighting) 53 10-04-2017 02:10 PM
Rear Seat Delete ML Interior Parts (Incl. Lighting) 21 04-25-2014 12:35 PM
REAR SEAT DELETE SUB BOX NYCsubaruBRZ NY / NJ / CT / PA 19 01-28-2014 02:38 AM
