Old 12-11-2014, 11:01 AM   #1
OkieSnuffBox
Drives: '23 BRZ Limited
Has anyone used this rear seat delete kit?
http://www.rearseatdelete.com/FRS-BRZ.html
I looked through some old threads but didn't find any mention of anyone actually purchasing or installing it.
Looks good, price is right (that Seibon looks out of place and is horrendously expensive).
I don't have kids and we are getting a dog, so I thought this would be a better option than getting fur all in the seats and potentially tearing them up when I have to take him somewhere.
I know I could lay the seats down, but I like the look and it drops the weight of the car a touch.
Old 12-11-2014, 11:09 AM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
ABS plastic... I don't think this will bear any load.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 12-11-2014, 01:33 PM   #3
swarb
How does the top portion stay in place? and is it movable open/close without tools?
Old 12-11-2014, 03:08 PM   #4
OkieSnuffBox
I emailed the guys at rearseatdelete.com, here is the answer I received:
"The weight capacity depends on where you place the weight. It’s strongest in the center over the trans tunnel where it could hold 150 lbs, but out towards the edges it can’t hold as much, so if you can keep your dog in the center, he’d be fine."
Old 12-11-2014, 03:36 PM   #5
mid_life_crisis
Drives: FR-S 10 #103 AT
There are a couple of threads on this. One actually asked the exact same question.
I had two dogs with a combined weight of about 150 pounds back there. I took out the divider so they could spread out. I did cheat while the dogs were back there and temporarily put some reinforcement under the leading edge of the seat but they were fine for a two hour trip.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 12-11-2014, 06:01 PM   #6
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
If you are good with wood you can fab up your own rear seat delete. I made one that weighs 12 lbs less than stock (seat bottoms and backs) and can support my weight (~150 lbs). Below are pictures of it installed. The carpeting material I picked up from Pep Boys was nearly identical. It's a little darker initially, but over time as it wears it blends in well. Best part is people think it's stock.
Rear Seat Shelf by jdkane527, on Flickr
JDKane527 is offline   Reply With Quote
The Following 2 Users Say Thank You to JDKane527 For This Useful Post:
jliongh (09-24-2016), mrlewistan (12-12-2014)
Old 12-11-2014, 06:23 PM   #7
JoeC
Drives: Subaru BRZ Limited
Originally Posted by JDKane527 View Post
If you are good with wood you can fab up your own rear seat delete. I made my own that weighs 12 lbs less than stock and can support my weight (~150 lbs)
pics or link?
JoeC is offline   Reply With Quote
Old 12-11-2014, 08:54 PM   #8
8R6
8R6's Avatar
Drives: FRS
i wanna know this too
8R6 is offline   Reply With Quote
Old 12-11-2014, 10:11 PM   #9
kwebb1086
Drives: asdasdf
Also looking on info on any plywood or other diy kits. I have a 60 lb and 30 lb dog that apparently are not going to do well with the schrader kit.
kwebb1086 is offline   Reply With Quote
Old 12-11-2014, 10:47 PM   #10
aznatama
aznatama's Avatar
Your dogs won't easily get into the back seat anyways... You going to remove your partner seat?
'14 BRZ LTD MT DGM
Old 12-11-2014, 11:29 PM   #11
JDKane527
JDKane527's Avatar
Originally Posted by JoeC View Post
pics or link?
Added pictures to the original post.
Old 12-12-2014, 12:03 AM   #12
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
that is fantastic work
mrlewistan is offline   Reply With Quote
Old 12-12-2014, 11:49 AM   #13
mid_life_crisis
My 11 year old overweight lab got in and out with no problem.
Although, now that I think about it, he got in by going over the passenger seat and hanging a left at the center console. My armrest probably helped out there.
Old 12-12-2014, 11:53 AM   #14
mid_life_crisis
Nice work.
The only advantage the kit has is that it is split and lifts up to turn the space where the seat bottom was into hidden storage.
DIY: Shrader Performance Rear Seat Delete Kit & Rear Seat Removal PoorMansRacing DIY (Do-It-Yourself) Guides 98 10-10-2023 04:51 PM
Rear Seat Delete kit ender2664 Cosmetic Modification (Interior/Exterior/Lighting) 53 10-04-2017 02:10 PM
Rear seat delete? s30series Cosmetic Modification (Interior/Exterior/Lighting) 12 11-16-2014 11:13 PM
REAR SEAT DELETE SUB BOX NYCsubaruBRZ NY / NJ / CT / PA 19 01-28-2014 02:38 AM
