Old 11-16-2014, 03:54 AM   #1
impossible
butt connectors question
hi guys,
new to the in-stallion of stereo in our car and would like to know when and how to select the butt connectors for out car. and when do we need to use it if we have got all the harness for the iso and the stereo itself. as i saw from youtube there are 14-16 gauges 18-22 gauges. thanks.
i am planning to install a single din pioneer headunit.
impossible is offline   Reply With Quote
Old 11-16-2014, 08:22 PM   #2
MasterMech77
MasterMech77's Avatar
Drives: 2014 Scion FRS 10 Series
OK main thing is they make harness adapters (http://www.crutchfield.com/p_120701761/Metra-70-1761-Receiver-Wiring-Harness.html?tp=297)
The BEST way is to soldier and use weather resistant heat shrink on the wires.([ame="http://www.amazon.com/Heat-Shrinkable-Wire-Wrap-Set-24-piece/dp/B0042YUAR8/ref=sr_1_12?ie=UTF8&qid=1416186912&sr=8-12&keywords=heat+shrink"]http://www.amazon.com/Heat-Shrinkable-Wire-Wrap-Set-24-piece/dp/B0042YUAR8/ref=sr_1_12?ie=UTF8&qid=1416186912&sr=8-12&keywords=heat+shrink)[/ame]
However if you must use butt connectors use the heat/self soldering ones.
([ame="http://www.amazon.com/Waterproof-Solder-Shrink-Connectors-Soldering/dp/B00ESXX74G/ref=sr_1_1?ie=UTF8&qid=1416187131&sr=8-1&keywords=soldering+butt+connector+with+heat+shri nk&pebp=1416187134397"]http://www.amazon.com/Waterproof-Solder-Shrink-Connectors-Soldering/dp/B00ESXX74G/ref=sr_1_1?ie=UTF8&qid=1416187131&sr=8-1&keywords=soldering+butt+connector+with+heat+shri nk&pebp=1416187134397)[/ame]
or even these will work in places not expecting to get moisture in:
([ame="http://www.amazon.com/22-18-Shrink-Solder-Electrical-Connectors/dp/B00FEIWP7O/ref=sr_1_6?ie=UTF8&qid=1416187131&sr=8-6&keywords=soldering+butt+connector+with+heat+shri nk"]Amazon.com: 22-18 AWG Red Heat Shrink Solder Electrical Butt Connectors Qty (25): Home Improvement[/ame])
Hope this helps and feel free to ask any questions you like. I have been working vehicles for 20 years and have done tons of custom sounds system installs.
2014 Sc10n FRS 10-Series
#655 of 2500
MasterMech77 is offline   Reply With Quote
The Following User Says Thank You to MasterMech77 For This Useful Post:
impossible (11-18-2014)
Old 11-17-2014, 02:15 AM   #3
Poodles
Drives: 2015 Series.Blue
The BEST way is to use proper crimps as they're best in a high vibration environment (in other words, a car). Soldering takes up less room, but it causes higher resistance and brittleness of the wire.
Regardless, you're really asking about the wire gauge, and that I cannot tell you as I don't have the wires in hand to measure.
Car butt smells evan Northwest 15 01-13-2014 09:36 PM
Diode Dynamics kicks serious butt! Evil Jesus User/Vendor/Sponsor Reviews, Feedback, Comments 1 01-07-2014 05:58 PM
Where'd the monkey butt red go? n2oinferno Scion FR-S / Toyota 86 GT86 General Forum 12 03-28-2013 04:20 PM
Which Butt? (NSFW) Atticus808 Off-Topic Lounge [WARNING: NO POLITICS] 8 03-09-2013 10:17 PM
Monkey Butt Red FR-S Evil86 Member's Car Journals 1 06-09-2012 08:49 PM
