Drives: None
AI versus Drop-In WITH TUNE
So I know and always see people saying throw a drop in, it makes more sense for your money for this car BUT
If I am getting an OFT Wouldn't the gains from an Intake System actually make sense at that point vs. a drop-in AKA will an actual intake be more utilized with the OFT vs a simple drop in? |
#2 | |
Vishnu/openflash are releasing a tune for the new Grimmspeed intake, so if you really want an intake I would go with that. |
Drives: None
Yeah i saw that topic hence my question, basically even vs the grimmspeed intake should i get a drop in, will it still be worth the money?
#4 | |
Also, at this point in time OFT+Grimmspeed is the only (canned) open flash tune specifically made for making additional power with an aftermarket intake. If you are going to get a custom tune, you could probably get any intake you prefer. |
Drives: 2015 WRX
I have a perrin drop in along with silicone inlet tube and I just purchased a grimmspeed intake for more stable AFR levels. Dropins with inlet tubes are perfectly fine but the grimmspeed intake appears to make a tiny bit more power along with more consistent AFRs.
Just out of curiousity did you rescale maf with dropin and silicone intake tube or are you saying the afr vary from day to day ?
#7 | |
Drives: 2015 WRX
I don't want to assume anything but it appears that Shiv might want to spend some time looking at anything that would affect fueling during warmup (ie MAF compensation IAT). That or I need a new primary O2 sensor, which I guess is possible. Last edited by Malt; 11-14-2014 at 06:53 AM. |
#8 | |
![]() Their is also a MAF sensor temp compensation table http://www.ft86club.com/forums/showp...5&postcount=85 ![]() solidOne has done a bit of work on this . |
| OFT+OFH+Perrin drop-in filter... need custom tune? | dejxx | Software Tuning | 11 | 09-10-2014 02:25 PM |
| Michelin PSS versus AS/3 | boomslang | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 07-22-2014 11:40 PM |
| E85 versus 100 octane | Deep Six | Software Tuning | 14 | 11-12-2013 07:02 PM |
| OEM HID versus TRS HID | Anomie | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 10-24-2013 04:03 PM |
| Drop in, silicone tube, exhaust, NO tune...problems? | BlackyRose | Engine, Exhaust, Transmission | 19 | 07-06-2013 12:57 PM |
