Old 04-28-2014, 08:51 PM   #1
dejxx
dejxx's Avatar
Drives: FT-86
OFT+OFH+Perrin drop-in filter... need custom tune?
So... my OFH arrived at home!!! (finally... possibly the first south-american customer so far...?). Im installing it when i get back (2 weeks from now ... sad sad).
I also ordered a Perrin Drop-in filter. Question is... will the off the shelf stg 2 UEL work? or do i need a custom tune just because of the filter?
I know that if you get an intake its needed.. but with just the filter???
Thanks!!
dejxx is offline   Reply With Quote
Old 04-28-2014, 09:12 PM   #2
wparsons
wparsons's Avatar
You'll be fine, you shouldn't have to adjust the tune because of the filter at all.
flickr
Old 04-28-2014, 09:43 PM   #3
dejxx
dejxx's Avatar
Drives: FT-86
Thanks for the reply!!
Old 04-28-2014, 09:55 PM   #4
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
Like he said, you won't need a custom tune. I believe that the car Shiv used to make the tune had the Perrin filter installed (Though I think it also had a modified air duct).
Any which way, you'll be good to go.
alexand3r is offline   Reply With Quote
Old 04-29-2014, 12:31 PM   #5
Robert@Openflash
Robert@Openflash's Avatar
Drives: C6 Z06
You have all the parts we run on our shop car. With your setup you want to run our OTS Stage2 UEL Map and you will be perfectly fine.
You do not need an aftermarket intake. However if you do plan on staying NA I would look into the Crawford BPB as it provides decent gains.
Thanks!!
Robert@Openflash is offline   Reply With Quote
Old 04-29-2014, 02:25 PM   #6
dejxx
dejxx's Avatar
Drives: FT-86
Thanks for the reply and info!!! That BPB sounds good... will see on the long run.
On the same topic as before, would i need a tune if a get an inlet hose replacement? lets say Perrin, Mishimoto, etc..? Are the gains worth it? I dont mind deleting that awfull sound tube either... hehehe.
Old 05-02-2014, 11:53 AM   #7
Robert@Openflash
Drives: C6 Z06
You will not need a tune if you are changing out your inlet hose just run our stage 1 if you don't have headers and you shouldn't have any issues.
Old 06-12-2014, 05:48 PM   #8
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
@dejxx is the rest of your exhaust stock? If so, I'm looking at doing the same thing and would like to hear how it sounds, any video clips?
BirdTRD is offline   Reply With Quote
Old 09-08-2014, 06:11 PM   #9
cliffm
Is it worth getting the inlet hose? Or should I just save up and get OFH?
cliffm is offline   Reply With Quote
Old 09-08-2014, 06:24 PM   #10
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Inlet hoses are not really worth it until you have nothing else left to do. Definitely put it to the OFH fund. Must bigger improvements going that route.
Old 09-08-2014, 09:39 PM   #11
sirsol66
Drives: 2013 FRS- Hot Lava
To clarify then, you guys have built the open flash tunes with the perrin drop in filter? I didn't realize that, I thought it was on the stock filter. Do you think its worth the $40 or whatever it costs to upgrade to the Perrin over stock?
sirsol66 is offline   Reply With Quote
Old 09-10-2014, 02:25 PM   #12
Robert@Openflash
Drives: C6 Z06
Yes its worth the $40 to upgrade the filter using the Perrin over stock. We have them in stock if you need on let us know.
SOLD - Perrin Drop in Air Filter, NEW Amadeus Engine, Exhaust, Bolt-Ons 3 08-20-2013 10:54 AM
SOLD: Perrin Drop In Filter (MD) yamsta Engine, Exhaust, Bolt-Ons 2 07-11-2013 12:52 PM
Perrins new CAI vs Perrin drop in filter. Thoughts? NickFRS Engine, Exhaust, Transmission 76 01-22-2013 12:39 AM
FS: Perrin drop in filter SubaSteve Engine, Exhaust, Bolt-Ons 4 01-21-2013 12:04 PM
