Old 07-05-2013, 04:11 PM   #1
BlackyRose
Drives: 2013 Raven FR-S
Drop in, silicone tube, exhaust, NO tune...problems?
Anyone have problems with the following mods and no tune, just stock ecu.
Drop in filter
Silicone intake tube
Exhaust
Don't care about responses telling me to search or how I need a tune. just wanted a quick poll if anyone had problems with these mods on a stock ecu. I'm sure no one has, but curious nonetheless and it would take hours to search through hundreds if pages of different breather mod posts
BlackyRose is offline   Reply With Quote
Old 07-05-2013, 04:35 PM   #2
jm1681
Drives: MKVI VW GTI
Friend has all three on his BRZ, no tune no problems.
Probably more WITH a tune, but I think you'll be totally fine bolting on and going for it
jm1681 is offline   Reply With Quote
Old 07-05-2013, 05:21 PM   #3
BlackyRose
Thanks. I am 100% sure its fine, in fact Ive read on here that many people have a lot of breather mods without a tune. I was attempting to lure that 1 guy that has a problem (if he exists) and then order my parts according to his advice of what to stay away from
Old 07-05-2013, 05:39 PM   #4
jflogerzi
jflogerzi's Avatar
You will be fine because the MAF is still in the OEM location. You might run a bit richer due to more airflow, but those 3 should be 100% fine without a tune. Might eek a bit more with a tune.
Old 07-05-2013, 06:21 PM   #5
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Exactly. Running these mods without a tune as well; no issues. Would recommend resetting the ECU though after installation.
Nightbringer is offline   Reply With Quote
Old 07-05-2013, 06:37 PM   #6
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
I have Perrin drop in Filter and intake tube with TRD exhaust. Car runs much better than stock and I have had no problems. I did unplug the battery for about 10-15 minutes to reset the computer when I added the parts. So far all is well.
MTCRX is offline   Reply With Quote
Old 07-05-2013, 06:53 PM   #7
Blood
Drives: 2018 STI
Another one here with those three mods and no tune.
I have:
Perrin inlet hose
Perrin drop-in filter
Perrin 2.5" catback exhaust
Been running with those mods for 5k miles and no issues.
Blood is offline   Reply With Quote
Old 07-05-2013, 06:58 PM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
Same here no issues. Wish I could try a tune to see the difference.
Old 07-05-2013, 07:02 PM   #9
BlackyRose
Are all of you guys above ^^ pretty satisfied with just the reset ECU and those mods?
Old 07-05-2013, 07:06 PM   #10
Nightbringer
Drives: Scion FR-S
From dynos and what everyone says, a tune makes a night and day difference. However, I've put 7000 miles on with intake/exhaust and no tune and am very satisfied with the results. Marginal power gains in the grand scheme of things, but there've been no issues/problems, and gas mileage has only gotten better.
Old 07-06-2013, 02:24 AM   #11
Fast_Freddy
Drives: Passat
It won't run richer. The MAS will see the extra airflow, tell the ECU and the ECU will add the correct amount of extra fuel. Then the wide-band O2 sensor (Toyota calls it an "AFR sensor") will monitor the actual AFR and the ECU will fine-tune the fuel trims to achieve the target AFR every time. All long term fuel trims also contribute to open loop table corrections so that the open loop AFR should also remain unchanged.
There are a lot of good reasons to get a tune but the only engine mod that actually NEEDS a tune is forced induction.
Fast_Freddy is offline   Reply With Quote
The Following 2 Users Say Thank You to Fast_Freddy For This Useful Post:
BlackyRose (07-06-2013), Nightbringer (07-06-2013)
Old 07-06-2013, 03:59 AM   #12
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Exhaust... full exhaust or catback?
LeeMaster is offline   Reply With Quote
Old 07-06-2013, 10:02 AM   #13
BlackyRose
That's one hell of an answer. Nice to see a post that stays on topic!! Thanks
Old 07-06-2013, 10:03 AM   #14
BlackyRose
Probably zeta or something else in that price range. Probably leave the stock front pipe just to keep my cost down.
AVO Silicone Intake and Sound Tube install and review ESC POD Engine, Exhaust, Transmission 38 05-21-2013 07:18 AM
Perrin CAI Intake and Silicone Tube chadstyle Engine, Exhaust, Transmission 24 04-30-2013 03:38 AM
AVO Silicone Inlets & Sound tube in stock! AVOturboworld Engine, Exhaust, Bolt-Ons 31 01-06-2013 12:52 AM
Perrin silicone intake tube & filter JoeBoxer Engine, Exhaust, Bolt-Ons 7 01-03-2013 09:44 PM
AVO Silicone Inlet and Sound Tube DIY AVOturboworld DIY (Do-It-Yourself) Guides 17 09-02-2012 01:35 AM
