Old 10-29-2014, 04:12 PM   #1
hahaman86
Drives: 2013 Scion FR-S 10 Series #2013
Tomei uel headers w/o heat shield
I just had my tomei uel headers installed on my frs, but when I asked the guy who installed them about the heat shield that the website lists is included for the oil pan, he said there was none in the box. I've read that the tomei headers bolt pretty close to the oil pan so I'm wondering if this is a cause for concern. Anyone with any information would be greatly appreciated. Last thing I need is to total my car because of something like this. Thanks
hahaman86 is offline   Reply With Quote
Old 10-29-2014, 04:13 PM   #2
CSG David
CSG David's Avatar
You get heat wrap tape with your box. If you installed it yourself, you will see a package with the heat wrap tape. If you didn't install it yourself, then your installer probably didn't know about it.
Old 10-29-2014, 04:38 PM   #3
hahaman86
If the heat wrap isn't installed is it going to cause problems?
Old 10-29-2014, 04:47 PM   #4
CSG David
CSG David's Avatar
You're radiating a lot of heat to the oil pan which isn't necessarily a good thing.
Old 10-29-2014, 05:07 PM   #5
hahaman86
Any possible solutions?
Old 10-29-2014, 05:31 PM   #6
Foobar
SLO NO MO
Foobar's Avatar
Get your installer to check the box for heat wrap. If that fails, procure heat wrap and apply to oil pan yourself.
Old 10-29-2014, 06:22 PM   #7
hahaman86
Where does one get heat wrap?
Old 10-29-2014, 06:57 PM   #8
CSG David
CSG David's Avatar
Something similar to this.
[ame="http://www.amazon.com/Thermo-Tec-13575-Adhesive-Backed-Barrier/dp/B00029KC2K/ref=sr_1_7?ie=UTF8&qid=1414623452&sr=8-7&keywords=heat+wrap+tape"]Amazon.com: Thermo-Tec 13575 12" X 24" Adhesive Backed Heat Barrier: Automotive[/ame]
Old 10-29-2014, 07:08 PM   #9
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
I don't see the point in putting this on your sump and leaving the rest of the engine unprotected.
Old 10-29-2014, 08:01 PM   #10
hahaman86
Please explain?
Old 10-29-2014, 08:06 PM   #11
Wayno
Wayno's Avatar
I think the oil temp in your sump is the least of your problems when you're radiating heat directly on to engine seals and everything else in the engine bay.
Old 10-29-2014, 11:19 PM   #12
hahaman86
What do you suggest I do?
Old 10-29-2014, 11:25 PM   #13
Wayno
Wayno's Avatar
Black ceramic coating inside and out. Unfortunately I only have mine done on the outside but I had the vendor do it and they warranty the headers for 3 years. Don't know if they can sandblast inside to get rid of the carbon buildup and coat inside now.
Or you could make heat shields easier than with catted headers. Coating does look better though.
Anyone heat coating their headers? BenArmstrong Engine, Exhaust, Transmission 29 12-29-2014 01:15 AM
Seibon TS hood heat shield texasbound972 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2014 11:08 AM
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
WTB: Front pipe cat heat shield Tim_Asphalt_FRS Engine, Exhaust, Bolt-Ons 4 09-19-2013 12:52 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
