Drives: 2013 Scion FR-S 10 Series #2013
Tomei uel headers w/o heat shield
I just had my tomei uel headers installed on my frs, but when I asked the guy who installed them about the heat shield that the website lists is included for the oil pan, he said there was none in the box. I've read that the tomei headers bolt pretty close to the oil pan so I'm wondering if this is a cause for concern. Anyone with any information would be greatly appreciated. Last thing I need is to total my car because of something like this. Thanks
#2 |
You get heat wrap tape with your box. If you installed it yourself, you will see a package with the heat wrap tape. If you didn't install it yourself, then your installer probably didn't know about it.
#3 |
If the heat wrap isn't installed is it going to cause problems?
#4 |
#5 |
#6 |
SLO NO MO
#7 |
#8 |
Something similar to this.
[ame="http://www.amazon.com/Thermo-Tec-13575-Adhesive-Backed-Barrier/dp/B00029KC2K/ref=sr_1_7?ie=UTF8&qid=1414623452&sr=8-7&keywords=heat+wrap+tape"]Amazon.com: Thermo-Tec 13575 12" X 24" Adhesive Backed Heat Barrier: Automotive[/ame] |
#9 |
Drives: Toyota 86 GTS
I don't see the point in putting this on your sump and leaving the rest of the engine unprotected.
#10 |
#11 |
I think the oil temp in your sump is the least of your problems when you're radiating heat directly on to engine seals and everything else in the engine bay.
| The Following User Says Thank You to Wayno For This Useful Post: | JP (10-29-2014) |
#12 |
#13 |
Black ceramic coating inside and out. Unfortunately I only have mine done on the outside but I had the vendor do it and they warranty the headers for 3 years. Don't know if they can sandblast inside to get rid of the carbon buildup and coat inside now.
Or you could make heat shields easier than with catted headers. Coating does look better though. |
| Anyone heat coating their headers? | BenArmstrong | Engine, Exhaust, Transmission | 29 | 12-29-2014 01:15 AM |
| Seibon TS hood heat shield | texasbound972 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 10-09-2014 11:08 AM |
| Racer X Fabrication heat shield, help us to help you | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 31 | 07-17-2014 09:20 AM |
| WTB: Front pipe cat heat shield | Tim_Asphalt_FRS | Engine, Exhaust, Bolt-Ons | 4 | 09-19-2013 12:52 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
