Old 10-22-2014, 10:59 PM   #1
Drewbie
Drives: 2013 Asphalt FRS 6AT
What gaskets do I need????
So I'm replacing my factory header with a borla, and my factory catback with a perrin. What gaskets do I need to replace? I've found I'll need 2 exhaust manifold gaskets and maybe 3 2.5" exhaust gaskets?
Any advice is appreciated. Thanks!
Drewbie is offline   Reply With Quote
Old 10-22-2014, 11:07 PM   #2
gramicci101
Off Topic
Get GrimmSpeed exhaust manifold gaskets. They're just better.
Old 10-22-2014, 11:25 PM   #3
cnk
Drives: '13 DGM BRZ Limited
Perrin catback should come with gaskets unless you're buying used. It uses v-band clamps so the only gasket you'll need is the one from the stock cat to the mid-pipe connection which comes with the exhaust from Perrin.
For the header install, I would use GrimmSpeed manifold gaskets as recommended above and you'll need 1 additional 2.5" gasket for the header to OP connection.
cnk is offline   Reply With Quote
Door window gaskets? dtrop Issues | Warranty | Recalls / TSB 4 07-03-2014 05:00 PM
Perrin cbe gaskets. merino_frs Engine, Exhaust, Transmission 5 01-06-2014 03:32 PM
Exhaust Gaskets Trashed675 Engine, Exhaust, Transmission 4 11-19-2013 07:43 PM
Gaskets Hawk77FT Engine, Exhaust, Transmission 2 09-27-2013 07:45 PM
Header gaskets Motordyne Engine, Exhaust, Transmission 1 06-23-2012 04:31 PM
