Old 11-19-2013, 07:04 PM   #1
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Exhaust Gaskets
I put my Borla UEL on last night with Grimmspeed header gasket and everything looks great, but I didn't replace the gasket from the header to the overpipe. Should I have?
What gasket should I use? Grimmspeed has a 2.5 inch universal or should I just use a replacement OEM subbie gasket?
Trashed675 is offline   Reply With Quote
Old 11-19-2013, 07:20 PM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
eitherway you should be fine
Old 11-19-2013, 07:24 PM   #3
Trashed675
Trashed675's Avatar
But I probably should have replaced it instead of reusing the old one?
Old 11-19-2013, 07:38 PM   #4
zc06_kisstherain
Drives: SWP BRZ
If old one looked fine then its ok. I reused mine on front pipe and axleback
Old 11-19-2013, 07:43 PM   #5
Trashed675
Trashed675's Avatar
Awesome, thanks.
It looked fine, but I was still second guessing myself because I totally spaced it until I was actually under the car.
Are new gaskets required with new headers? IAmNotTheDriftKing Engine, Exhaust, Transmission 20 11-14-2013 10:18 PM
Help: Overpipe back--replace which exhaust gaskets? OnTheFence Engine, Exhaust, Transmission 1 09-28-2013 12:18 PM
Gaskets Hawk77FT Engine, Exhaust, Transmission 2 09-27-2013 07:45 PM
Exhaust header / manifold gaskets (Subaru part number) ft_sjo Engine, Exhaust, Transmission 1 07-15-2013 09:24 AM
Header gaskets Motordyne Engine, Exhaust, Transmission 1 06-23-2012 04:31 PM
