Old 01-04-2014, 01:51 PM   #1
merino_frs
merino_frs's Avatar
Perrin cbe gaskets.
I bought a perrin 2.5 resonated catback exhaust. It didn't come with gaskets. Can I use any stock ones or can I go to the subaru dealership and see if the Lu have a gasket there. Thanks.
merino_frs is offline   Reply With Quote
Old 01-04-2014, 07:07 PM   #2
wparsons
wparsons's Avatar
What gasket are you looking for?
The v band connections don't need gaskets at all to seal properly, and the connection to the front pipe should use the stock donut gasket unless you're running an aftermarket front pipe.
flickr
Old 01-04-2014, 09:54 PM   #3
merino_frs
merino_frs's Avatar
The one that goes from the mid pipe to the cat.
Old 01-04-2014, 10:07 PM   #4
merino_frs
merino_frs's Avatar
Ahh i see. Thanks for your input. I was just confused because I saw a DIY and they replaced the stock donut gasket with a flat one.
Old 01-05-2014, 08:17 PM   #5
wparsons
wparsons's Avatar
You only use the flat gasket with certain front pipes. If you have the Perrin front pipe and cat back then you definitely need the flat gasket.
flickr
Old 01-06-2014, 03:32 PM   #6
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
It sounds like you need just the two bolt 2.5" flat gasket. We have those on our website in the exhaust section.
PERRIN_Chris is offline   Reply With Quote
GrimmSpeed BRZ/FR-S Exhaust Gaskets - Now Available! GrimmSpeed Engine, Exhaust, Bolt-Ons 2 01-19-2014 10:04 PM
Exhaust Gaskets Trashed675 Engine, Exhaust, Transmission 4 11-19-2013 07:43 PM
Are new gaskets required with new headers? IAmNotTheDriftKing Engine, Exhaust, Transmission 20 11-14-2013 10:18 PM
Gaskets Hawk77FT Engine, Exhaust, Transmission 2 09-27-2013 07:45 PM
Header gaskets Motordyne Engine, Exhaust, Transmission 1 06-23-2012 04:31 PM
