Old 07-03-2014, 03:41 PM   #1
dtrop
Drives: Wrb 2014 limited brZ
Door window gaskets?
Anyone have this problem? Owner for new 2014 from boat since May. Noticeable when washing my car, not necessarily during rain.
dtrop is offline   Reply With Quote
Old 07-03-2014, 03:57 PM   #2
stevemp5
Drives: scion fr-s
Yeah! Everytime i Wash my car. Goes away quickly!
stevemp5 is offline   Reply With Quote
Old 07-03-2014, 04:25 PM   #3
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
Thats normal. As long as it doesnt go past the second layer and into the cabin, you're good.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
Old 07-03-2014, 04:48 PM   #4
chas3wba0
chas3wba0's Avatar
Drives: Yes
Only happens when I wash the car as well, due to the fact that I spray pressured water directly at the crack. Part of the drying process involves opening the door to dry the sills and such anyway, so might as well give the window edges a quick wipe too, no big deal
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 07-03-2014, 05:00 PM   #5
dtrop
Okay, sounds good, just making sure it wasn't going to be an issue.
I'll make sure wipe dry the inside after I wash.
OEM parts? Burned rubber door/window sill l0aded Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 04-08-2017 07:32 PM
HVAC and window door switches white LED swap phanguy Interior Parts (Incl. Lighting) 4 04-17-2014 04:58 PM
Window and door lock switch Illumination question. HapaHaole BRZ First-Gen (2012+) — General Topics 0 03-05-2014 09:14 PM
Grazio Chrome Window Frame and Door Handle cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 20 07-12-2013 10:22 PM
Small window door issue (rubber seal) Subforever Issues | Warranty | Recalls / TSB 7 05-20-2013 05:32 AM
