Old 01-11-2013, 10:20 PM   #1
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
anyone experience engine knock on 91 octane?
as i was reading the manual i noticed that it says "if 93 oct is not available you can use 91 but might experience knocking". I can only find 91 in Canada so wondering if engine will knock.
Getting my car next week so can't tell myself.
chenshuo is offline   Reply With Quote
Old 01-11-2013, 10:26 PM   #2
Gixxersixxerman
Gixxersixxerman's Avatar
Drives: Toyota GT86, 66 beetle, 11 GSXR 750
We only have 91 here in so cal, and I live in the high desert and go up mountain passes quite a bit.. On my way to work a twice a day lol.. And I've n
Heard no knock yet.. If it is there I haven't noticed yet
Gixxersixxerman is offline   Reply With Quote
Old 01-11-2013, 10:51 PM   #3
ziggz501
ziggz501's Avatar
i have to use 90 in alaska, and i'm at sea level. works fine.
ziggz501 is offline   Reply With Quote
Old 01-12-2013, 12:26 AM   #4
Subynewbie
Subynewbie's Avatar
Drives: 2013 swp brz
Petrocanada sells 94 octane at most locations.
Subynewbie is offline   Reply With Quote
Old 01-12-2013, 01:11 AM   #5
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
is that what you use? must be really expensive.
Old 01-12-2013, 09:21 AM   #6
Subynewbie
Subynewbie's Avatar
I use it most of the time. Some people swear by shells premium, which is 91 here. It is ethanol free.
Old 01-12-2013, 10:51 AM   #7
GerryL
Drives: White BRZ
Actually higher altitude would have less of an octane requirement as the thinner air effectively reduces the compression.
GerryL is offline   Reply With Quote
Old 01-13-2013, 06:22 AM   #8
llama_au
Loud Noises
llama_au's Avatar
Drives: BRZ & YGZ11 Cube3
Woah! I wouldn't dream of running anything under 98 octane (non-ethanol), though I guess that sounds a bit easier here in Australia than for you guys. 91 octane is our minimum fuel here, then 95, then 98 and we used to have 100 octane on pump at selected stations (non-ethanol.)
Proud owner of an April 2013 WR Blue Mica BRZ Premium Pack
llama_au is offline   Reply With Quote
Old 01-13-2013, 06:38 AM   #9
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
The difference is because you guys use RON in Oz, and we use AKI in the states, which is an average of RON and MON. Ours will show 4-5 points lower but is still equivalent to yours. So your 98 is our 93.
- The Ancient BRZ Sacrament
by Zaku
Old 01-13-2013, 06:49 AM   #10
llama_au
Loud Noises
llama_au's Avatar
Oh I see, thanks for the explanation. I was getting worried!
Old 01-13-2013, 09:54 AM   #11
Jaylyons1
Jaylyons1's Avatar
Drives: 2022 WRB BRZ; 1993 Skyline GT-R
Torco FTW!
Jaylyons1 is offline   Reply With Quote
Old 01-13-2013, 10:39 AM   #12
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
Driving at anything other than WOT reduces effective compression too, so you'd really only expect to experience knock at full-throttle.
Admiral Ballsy is offline   Reply With Quote
Old 01-13-2013, 01:58 PM   #13
Wankel Rex
Wankel Rex's Avatar
Drives: Silver Premium Edition BRZ
I get stuck with 91 in certain parts of OK and MO when I'm driving between Ft. Worth and St. Louis. Only issue I've seen is a few misfires on cold morning starts. Dealer checked it out and the only recommendation they had was to use 93.
I haven't had the issue lately, but it hasn't been as cold.
Wankel Rex is offline   Reply With Quote
Old 01-13-2013, 04:58 PM   #14
Looker_007
Looker_007's Avatar
Drives: Firstorm A/T
Super in Montreal
Generally use Shell 91 without problems. Have used other stuff on the 401 to and from To without problems and Irving in Vermont.
Looker_007 is offline   Reply With Quote
Why you shouldnt support knock off companies.. showbe Engine, Exhaust, Transmission 44 10-29-2012 08:13 AM
Toyota FTS report engine issues with FR-S running 91 octane DYOLF26 Issues | Warranty | Recalls / TSB 24 08-06-2012 01:22 PM
Single knock when coming to a stop oops86 Issues | Warranty | Recalls / TSB 14 08-05-2012 01:17 AM
Mechanic says she's dead, Jim! Could knock me out of 1st86 Dadhawk Other Vehicles & General Automotive Discussions 14 04-13-2012 08:37 AM
Would you rather buy knock off parts for your car? EJ20 Engine, Exhaust, Transmission 63 11-02-2011 06:17 PM
