Old 10-15-2014, 07:06 AM   #1
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Water leaking but not from ac
Today I drove my frs to work and noticed that there was water leaking on the passenger side wich is weird because I did not use my ac this morning
Why would water leak without ac use?
Young_makaveli is offline   Reply With Quote
Old 10-15-2014, 07:14 AM   #2
Shady195
Drives: '13 10 Series FRS #1203
Was the fan on at all?
The AC compressor will kick in regardless of if the A/C is on or not in order to remove moisture from the air in your car when the fan is on.
Shady195 is offline   Reply With Quote
Old 10-15-2014, 01:52 PM   #3
Young_makaveli
Drives: 2013 frs
The fan was not on no
Old 10-16-2014, 09:06 AM   #4
Young_makaveli
Drives: 2013 frs
Bump
Old 10-16-2014, 09:28 AM   #5
CBR600RR
Drives: Raven Black
if your have your ventilation nob turned on to defrost the front windshield = your AC is on regardless of whether or not your AC button is pushed.
The Following User Says Thank You to CBR600RR For This Useful Post:
Young_makaveli (10-16-2014)
Old 10-16-2014, 09:44 AM   #6
Young_makaveli
Drives: 2013 frs
Come to think of it this happens only in the morning when I use my defrost
I didn't know that the ac turns on even tho there is no indicator light
Thanks
Old 10-16-2014, 02:05 PM   #7
tomkozski
Drives: 2017 WRB BRZ w/ PP
Seems like a common issue on the twins based on all the other threads - the drain tube for the a/c condenser gets blocked, and the water subsequently leaks into the passenger foot well. I have the same problem, going into the dealership on Saturday to get the leak fixed.
tomkozski is offline   Reply With Quote
Old 10-16-2014, 02:25 PM   #8
Young_makaveli
Drives: 2013 frs
Yeah me is not inside but outside the car
Old 10-16-2014, 03:15 PM   #9
Rapiddan45
Rapiddan45's Avatar
Drives: 2013 FR-S M/T Ultramarine
Then dont worry about it, it's just the condensation from your A/C. You'll notice it alot more if you live in a place that gets very humid.
2013 Ultramarine 6MT- Feal 441 coils, Whiteline 20mm front/18mm rear swaybars.
RPF1 17x9 +35. 245/40/17 RS-3 V2.
OFH, Invidia OP, Spencer Fab HFC FP, Invidia N1
C38 JRSC, JROC, Delicious Tune, Radium PCV Catch Can
Rapiddan45 is offline   Reply With Quote
The Following User Says Thank You to Rapiddan45 For This Useful Post:
Old 10-16-2014, 03:17 PM   #10
Shady195
Thanks
Freaked me out too the first time I ever had a newer car with working a/c lol
Sent from my SM-G900A using Tapatalk
The Following User Says Thank You to Shady195 For This Useful Post:
Old 10-16-2014, 03:40 PM   #11
Young_makaveli
Drives: 2013 frs
Thanks for all the feedback guys I appreciate it
Water leaking inside the trunk mashal Issues | Warranty | Recalls / TSB 5 03-04-2016 10:00 PM
Water leaking in from under the dash on the passenger side FRSNewb Issues | Warranty | Recalls / TSB 3 07-23-2014 07:52 AM
Leaking water pump DJCarbine Issues | Warranty | Recalls / TSB 11 05-13-2014 05:59 PM
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
