Old 06-13-2014, 02:03 PM   #1
FRSNewb
FRSNewb's Avatar
Water leaking in from under the dash on the passenger side
I already called my dealership to make an appointment to get this looked at but has anyone else experienced a build up of water under the dash on the passenger side near the glovebox, and that water leaks onto the floormat every so often? I'm thinking a seal of some sort went..
1993 Mazda MX-3 - *SCRAPPED* / 1999 Plymouth Neon - *WRECKED* / 2000 Chrysler Neon - sold / 2006 Honda CR-V - sold / 2019 Chevrolet Colorado - All Year Round Vehicle / 2013 Scion FR-S - Summer Car
FRSNewb is offline   Reply With Quote
Old 06-13-2014, 02:19 PM   #2
pche
Guy on internet
Drives: Slowly
It's your AC drain, probably clogged. Blow it out with air, and replace your cabin filter, it's probably dirty.
pche is offline   Reply With Quote
Old 06-13-2014, 03:43 PM   #3
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
+1
Old 07-23-2014, 07:52 AM   #4
AtlasMick
Drives: FR-S 2013 Asphalt
Do you have any aftermarket wires sent through the rubber grommet behind the battery?
AtlasMick is offline   Reply With Quote
Water Leak inside passenger side floorboard AtlasMick Issues | Warranty | Recalls / TSB 30 03-28-2019 04:43 PM
Water leaking inside the trunk mashal Issues | Warranty | Recalls / TSB 5 03-04-2016 10:00 PM
Leaking water pump DJCarbine Issues | Warranty | Recalls / TSB 11 05-13-2014 05:59 PM
Passenger Side Dash Mods ktech Cosmetic Modification (Interior/Exterior/Lighting) 14 01-08-2014 09:36 PM
I found an extra connector under passenger side dash. boredom.is.me Electronics | Audio | NAV | Infotainment 29 01-05-2013 09:43 PM
