Old 01-11-2013, 11:33 AM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Still Leaking?
I was measuring my car today to see how low I can go before I hit the ground and noticed ANOTHER pool of that liquid under my car.
It's coming out of that hole in the skid-plate, so honestly it could be from like, anywhere in the engine area.
My last oil change was done by the Toyota/Scion dealership, and was 3,700 miles ago. It seems to only appear if I'm pushing my car pretty hard the night before.
Any ideas?
636 is offline   Reply With Quote
Old 01-11-2013, 11:39 AM   #2
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
Did you check to see if the oil bolt is in correctly?
Check the dipstick for overflow? Check the oil filer for leaking? Check the area where you put oil in the car?
Why is the car not back at the dealership yet?????
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 01-11-2013, 11:46 AM   #3
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
Check the oil drain plug bolt. The bolt could be loose or isnt sealing. Some places dont always eplace the gasket/bolt whixh can lead to seating issues. The oil is more likely to come through at higher temps due to viscosity.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline   Reply With Quote
Old 01-11-2013, 11:47 AM   #4
Turbowned
Turbowned's Avatar
Drain plug is probably loose. "That liquid" is most certainly motor oil.
Old 01-11-2013, 11:48 AM   #5
636
636's Avatar
Drives: '23 CWP BRZ
Yeah, just took a video under the car and the drain plug is literally soaked. Off to the dealer.
Old 01-11-2013, 11:59 AM   #6
636
636's Avatar
Drives: '23 CWP BRZ
Quick question, does the fact that I have a muffler delete change anything? Like do you think they'll question me on it?
Old 01-11-2013, 12:00 PM   #7
YourFearlessLeader
Muffler has nothing to do with the motor.
keep it movin!
Old 01-11-2013, 12:06 PM   #8
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
You know, I've been looking into this, and I'm not sure that multigrade oil is less viscous at high temp. Take 0W-20 oil. The cold viscosity ("0W", "W" stands for "winter") is lower than the hot viscosity ("20"). Makes me think that most of the leaking happens when parked. But most of the dripping probably happens on the road with all the vibration and bumping causing the bubble of oil to break free and fall.
b.e is offline   Reply With Quote
Old 01-11-2013, 01:49 PM   #9
636
636's Avatar
Drives: '23 CWP BRZ
Just an update for everyone, I went to the dealer. When they had done the initial oil change they over-tightened the drain plug and cracked it. They replaced it + did a free oil change.
Old 01-11-2013, 01:55 PM   #10
OrbitalEllipses
Drives: Attitude
Cracked the PLUG? It's more likely to damage the threads on the inside of the pan.
Old 01-11-2013, 02:53 PM   #11
636
636's Avatar
Drives: '23 CWP BRZ
I couldn't tell you..if I'm still leaking, I'll let y'all know.
Old 01-11-2013, 03:05 PM   #12
OrbitalEllipses
Drives: Attitude
I'm assuming THEY told you they cracked the plug?
Possibilities: Not tighten enough; no crush washer; used old crush washer; used two crush washers; damaged oil pan. Cracking the plug would be nigh impossible methinks.
Old 01-11-2013, 03:11 PM   #13
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
yeah they probably broke the crush washer, i did my first oil change (out of free ones at the dealership) not too long ago and they never replaced the original crush washer (got my oil changed 3 times at 3 different dealerships) being cheap much? i think so...
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 01-11-2013, 03:12 PM   #14
whtchocla7e
Dealership will say anything they think they might get away with... if you don't want to be fed stories you need to appear like you know more about cars... or just have more common sense, than they do.
Live to drive another day
whtchocla7e is offline   Reply With Quote
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Brake fluid leaking from pistons/seals normal? Hanakuso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-06-2012 02:54 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 04:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 03:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 04:43 PM
