DADA
Drives: 2013
Water leaking inside the trunk
So I was replacing my rear signals to some LEDs and it had just stopped raining here.
I found water leaking through the lightning holes and the gasket for the rear light was very wet. I ran my hand through to the bottom of the trunk as far as I could and it was all very moist. My concern is rust over the years .. Anyone else had this issue? |
Drives: Fast
There are holes in the body in which many people have reported that the dealers were failing to install the plugs.
I believe there's one around the coil and quite a few on the bottom. Take it to the dealer and have them check to make sure the plugs are installed. I believe the plugs are not installed at the factory due to shipping overseas. It lets the car breath so it doesn't get condensation and start to rust from the salt air. |
Drives: '13 Ultramarine
The OEM nuts for the tail lights are too small. The flange on the nut doesn't even cover the hole where the stud comes through the body. I noticed the same thing this week before I took the car in for the tail light TSB. In Subaru's latest TSB for the condensation issue, there are new nuts with a larger flange that covers the hole better. You should be able to get them at any Subi dealer. The TSB at my Toyota dealer didnt list the updated nuts, so I don't think they can get them yet.
I went to my local nut & bolt store and got some 3/16" I.D. X 3/4" O.D. fender washers to use with the OEM nuts. They fit the stud perfectly and should be large enough to keep water out.
Drives: FR-S 6MT
There should be 2 rubber plugs in front of the rear wheels on the subframe.
These are used as hold downs in transit. They should be plugged by the dealer as part of the PDI. Check to see if you have them. There is a thread on this if u do a search.. |
Drives: 2013 White-Out FRS
Sorry to bring this up again, but didn't want to make a new thread. Will the dealer help with this issue? My trunk is soaked cause of this area in the tail lights.
I live my life one quarter-pounder at a time.
#6 | |
Even if it's not, I'd suggest you give them a go. Maybe a TSB applies.....?? humfrz |
| Leaking water pump | DJCarbine | Issues | Warranty | Recalls / TSB | 11 | 05-13-2014 05:59 PM |
| Water in trunk | Spencer | BRZ First-Gen (2012+) — General Topics | 14 | 03-15-2013 10:17 PM |
| I found a place to make water and soil into the car inside | ladios | Issues | Warranty | Recalls / TSB | 6 | 02-04-2013 09:11 AM |
| Water inside the car? | YourFearlessLeader | Issues | Warranty | Recalls / TSB | 10 | 12-16-2012 04:55 PM |
| Vendors (business opportunity inside): Grazio GT/86 Trunk Lip Spoiler!!! | @Art_Mighty | Cosmetic Modification (Interior/Exterior/Lighting) | 19 | 11-17-2012 04:00 PM |
