Drives: Scion FR-S 10 Series #2263
Corroded pins/connectors in light harness
I am trying to replace some extremely corroded connectors in a harness for a DRL light strip. (this one: http://www.ft86club.com/forums/showthread.php?t=25959)
I bought the kit second hand, but stupid me, didn't ask for more pictures of the connectors and didn't think road salts would be so devastating on supposedly weather sealed connectors. I learned my lesson, I just want to fix it up so I could use this. The female terminals: ![]() ![]() ![]() ![]() The male terminals: ![]() ![]() ![]() ![]() ![]() Does anybody know what these things are called and where I can buy them? I'll probably need 4, to repin/terminate all the connectors. Thanks in advance for any help or advice. *EDIT* After some more digging based off of @jonzhuxD's suggestion, I have found the actual datasheet for the connectors and housing. Check it out: http://www.seaps.com.sg/pdf/b_mt_e.pdf Last edited by aegisdrgn; 10-06-2014 at 03:49 AM. Reason: Added more pictures. |
Drives: 2014 Subaru BRZ limited
Go to radio shack purchase a spray can of gold connector this product will clean and seal your present connector without replacing product cost about $20.00.
Unfortunately, I didn't take a picture of the REALLY corroded connector. The rounded tip on the worst one has broken off and it no longer makes a connection to the female portion, so I need a new one.
Drives: Ultramarine FR-S
They're Denso connectors. Here's a link to some, might be able to find them cheaper, I just grabbed the first link on eBay.
http://cgi.ebay.com?ViewItem&item=400778203186 |
| The Following User Says Thank You to jonzhuxD For This Useful Post: | aegisdrgn (10-06-2014) |
that's exactly it! Thanks a lot! Now to find a cheaper version...
Drives: FRS
CocaCola will remove the corrosion, you can use a variety of protection products, I use the battery stuff myself.(its red.. idk what its really called)
you can clean corrosion like that with coke about 3 times before the terminal will become useless in my experience.
| OEM Tail light connectors | aschnell | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 11-02-2021 03:02 PM |
| BRZ Radio Breakout Harness and/or Pins and Sockets | nquillen | Electronics | Audio | NAV | Infotainment | 4 | 06-22-2014 10:40 PM |
| Fog Light Harness | mit_peid | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 06-20-2014 02:39 AM |
| Fog light harness? | Perry | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-04-2013 03:32 PM |
| Foglight Harness Pins for sale | FRSHunter | Hawaii | 3 | 08-22-2013 12:29 AM |
