Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Fog Light Harness
I've bought the GT86 fog light bezels for my FRS and about to buy the OEM H11 Outback fog-lights like some others on these forums, but I was wondering if anybody has any experience with this harness from Nigel JDM parts?
http://www.nigel-jdmparts.com/lights...h-onoff-switch I understand to truly make it JDM-like, I should get the OEM stalk with the fog light switch to get the factory fog-light indicator to come on, but this seems to be a simpler and less costly option. Curious as to why Nigel is carrying this as "JDM" part too... |
#2 | |
#1362
Drives: 2014 Ice Silver WRX
the kit does have everything you need, but i had to extend some cables to make it useful. everything is very short. the fog light button feels pretty cheap but works fine and it fits into the USB/AUX spot in the car perfectly. overall a good kit, but you'll likely have to extend some of the cables.
Drives: 2013 scion fr-s
Get the stalk and do it the JDM way IMO.
#4 | |
Drives: Whiteout FR-S
I'm quite disappointed with this aspect of the nigel-jdm fog light harness. There's only so many ways you can run the wires and I can't see a way that would leave you with enough spare wire to be able to run them along existing factory wires so they're not looking so out of place. Sent from my Nexus 5 using Tapatalk |
#5 | |
#1362
Drives: 2013 FRS
I bought my foglights from Nigel JDM parts before the complete kits came out from Winjet and Sypder with switches that fit OEM style. I did not like the Nigel harness at all or the switch and I did not use them. Instead I did some research on the factory fogs and learned how to use the factory wiring already in the car complete with relay. I picked up a Winjet kit just for the switch and chopped up a harness from Didode Dynamics for the power/ground connection between the fog lights and the car wiring. Power for the fogs is on the turn signal connector which is above each parking light and hard to remove from its clips without the bumper removed. There is a plug in an unused slot on one side with the corresponding opposite wire being the fog power supply already to go. Used a T-dap slice to connect the power to the lights each side and then ran the ground to the ground locations on each side of the chassis. Only need about about a foot for the power and maybe two feet for the ground. One is basically closing an open circuit which is what the OEM Kit does. To hook up the switch I opened up the lower dash and cut off the factory connector that the OEM kit uses and cut off the wires from the Winjet switch leaving enough to splice the switch to the OEM wiring. There are four wires,, Yellow black went to the switch ground, White was power to the switch, and the other two (I dont remember their colors, sorry) connected to the relay and to the switch light. The Winjet switch goes in where the blank is next to the dimmer wheel. No drilling or having to adapt. Results: Fog lights operate like OEM. Dash inidicator works, fogs turn off automatically when high beams come on , fog lights can be turned on and off at will. Only exception is that the switch lights inversely to the dimmer control. I keep the dimmer at halfway and everything is even. At this point in time one just needs one kit from Winjet or Spyder (their switch setup is more OEM styled than Winjet and use the parts for the above. Here is a link to the OEM fog light install directions from Scion.
http://www.trdsparks.com/install/PT413-18130inst.pdf It has all the pictures that illustrate what I did as well as step by step instructions. Last edited by Wizardhat; 06-20-2014 at 02:41 AM. Reason: editing misspelling |
| Harness Bar | diirk | Tracking / Autocross / HPDE / Drifting | 38 | 07-21-2017 01:15 PM |
| Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) | ZetaPerformance | Exterior Parts - Lighting | 172 | 11-13-2015 10:25 AM |
| FS: Rear Reverse / Fog light Delete with Harness | taimysho0 | Exterior Parts (Aero, Lighting, Etc.) | 13 | 06-03-2013 11:29 AM |
| FS: Nigel fog light harness | Manny4115 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 04-09-2013 12:21 AM |
