Old 02-17-2014, 10:19 PM   #1
aschnell
OEM Tail light connectors
Looking to wire the fog light as 4th brake light. Wanted to do a plug and play solution. I think I found the connector and a source. Not 100% positive these are the right ones but pretty sure they are. Ordered some and will update post later to confirm either way.
Sumitomo TS 090
A guy in Japan sells these. Bought some other connector from him for my Honda before. www.Easternbeaver.com
aschnell is offline   Reply With Quote
Old 02-17-2014, 10:30 PM   #2
Sportster
Sportster's Avatar
Drives: '14 BRZ
I'd be interested if they turn out to be the correct connectors.
Sent from my SGH-I337 using Tapatalk
Sportster is offline   Reply With Quote
Old 02-17-2014, 10:31 PM   #3
sirsol66
Drives: 2013 FRS- Hot Lava
Interesting, having to cut into the OEM harness is the main reason I haven't installed rear fogs yet. Let us know your results.
sirsol66 is offline   Reply With Quote
Old 02-27-2014, 07:44 PM   #4
aschnell
Correct Connectors
So i got the connectors today and they are the correct ones. Took 10 days from placing the order from Japan to east coast USA with standard cheap shipping. Not bad.
These are the two parts you need to make up a cable.
4 Position TS 090 Male Connector
Item# 4P-TS090-M
4 Position TS 090 Female Connector
Item# 4P-TS090-F
I checked the wiring diagram for the pinout. Wire colors ( i tested these with a multimeter)
Light Green - STOP
Black - GND
Yellow/Green - Turn
Red - Tail
Going to crimp/solder up a cable to run my 4th brake light tomorrow. Dont expect any surprises.
Old 02-27-2014, 08:30 PM   #5
sirsol66
Sorry but could you link to the actual connector? I clicked around on the site but couldn't find the two PN's you have listed. Thanks
Old 02-27-2014, 08:45 PM   #6
NemeGuero
Would love to know where you got them and pricing.
NemeGuero is offline   Reply With Quote
Old 02-27-2014, 10:58 PM   #7
aschnell
http://www.easternbeaver.com/Main/El...onnectors.html
On this page. TS series 4 position connector.
$4.19 ea for male/female with crimp pins. You will probably need some sort of universal crimp tool. I have one at work so I didn't need one.
Old 04-08-2014, 12:47 AM   #8
NemeGuero
Finally got my connectors! took about a week and a half. Gonna get started on my Y harness tomorrow!
Old 06-27-2020, 07:27 PM   #9
Plumbus
Señor Member
Plumbus's Avatar
Drives: '17 BRZ PP
Fantastic find OP, I was looking for these connectors as I didn't want to wire the iJDMToy 3rd brake light permanently to the car wiring. Until I find the time to research and route a long cable for fog light functionality from the front fogs, this will do nicely.
That said, either you posted the wrong link or the website got updated and ruined the link, but that link takes you to HM and MT type connectors. The correct link to TS series connectors is this:
https://www.easternbeaver.com/Main/E...090/ts090.html
Plumbus is offline   Reply With Quote
Old 07-02-2020, 02:46 PM   #10
Chuckls
Moutain Runner
I have a friend that makes PnP harnesses for 4th brake lights. They're like $12 shipped.
Chuckls is offline   Reply With Quote
Old 07-07-2020, 11:39 AM   #11
pistolgrippoet
IMCF
Drives: 2016 Subaru BRZ Limited
I'd be interested in one. Care to link?
pistolgrippoet is offline   Reply With Quote
Old 07-07-2020, 10:14 PM   #12
Chuckls
Moutain Runner
https://www.facebook.com/groups/FRSB...31256113672267
Old 11-02-2021, 03:02 PM   #13
dkdnt232
Drives: 2013 subaru brz, 1979 toyota hilux,
i use this for whoever needs one in the future:
https://www.ebay.com/itm/303483893103
dkdnt232 is offline   Reply With Quote
Valenti tail light signal light issue djdnz Cosmetic Modification (Interior/Exterior/Lighting) 70 12-03-2017 12:49 AM
Tail light ? mousekilla15 BRZ First-Gen (2012+) — General Topics 2 07-30-2013 08:03 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
FS - Light tinted tail light overlays seven Exterior Parts (Aero, Lighting, Etc.) 0 01-26-2013 10:05 PM
experiencing tail light + fog light condensation? whyreeto AUSTRALIA 20 01-14-2013 11:15 PM
