CANADA Canada
Old 10-02-2014, 10:45 PM   #1
oppiee
Drives: 2014 Scion FRS (Red)
Quick question about manual shifting
Hey guys,
I got a quick question on manual shifting.
I know you are not suppose to skip gears when you up shift.
However, sometimes when you come to a stop say from gear 5 and you brake...then need to go again but you are at a speed for gear 3. Its ok to skip gear 4 and just go to 3 and accelerate?
Wont kill the tranny right?
oppiee is offline   Reply With Quote
Old 10-02-2014, 10:54 PM   #2
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
Based on my experience on forza. If you are downshifting then you could go from 5 to 1 if you are at a stop
904FRSlow is offline   Reply With Quote
The Following User Says Thank You to 904FRSlow For This Useful Post:
WallsAndFoundations (10-08-2014)
Old 10-02-2014, 11:08 PM   #3
oppiee
Forza Awesome HAHA.
The Following User Says Thank You to oppiee For This Useful Post:
pushrod (10-07-2014)
Old 10-02-2014, 11:10 PM   #4
gramicci101
Off Topic
As long as you let the synchros do their jobs you're fine. It helps to rev match on the downshift.
The Following User Says Thank You to gramicci101 For This Useful Post:
oppiee (10-03-2014)
Old 10-02-2014, 11:24 PM   #5
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
A generally good rule of thumb for whether or not something is "killing" your tranny is if you wince when you feel or hear what you just did. Not a catch all, but generally when the car seems extremely unhappy about the idea you just had, you should take its advice
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
The Following 4 Users Say Thank You to fatalelement For This Useful Post:
oppiee (10-03-2014), Tcoat (10-08-2014), WallsAndFoundations (10-08-2014), Wilso (10-07-2014)
Old 10-03-2014, 12:19 AM   #6
stugray
Drives: 2013 GBS BRZ Limited
The transmission does not have any magic in it that knows if you skip any gears, upshifting or down.
You can skip from any gear to any other gear if you know what you are doing.
caveat: I essentially never downshift to first ever, unless stopped, just an old habit.
If I am passing someone, I might wind it out in third or fourth, then just drop to 6th and coast back to the speed limit.
Or when I am coasting to a stop, I might leave it in a high gear all the way down to 1000 RPM, then slip out into neutral, and choose to coast to a stop, or pick 2nd or 3rd if the light changes and I need to go again.
If you make the bigger jumps slowly (letting the synchros work) or rev match, you are not being hard on the tranny.
The Following 3 Users Say Thank You to stugray For This Useful Post:
oppiee (10-03-2014), Wilso (10-07-2014), wparsons (10-07-2014)
Old 10-07-2014, 11:45 AM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Whyyyyy do you "know" this? Who told you this?
This is a myth that's been present ever since the dawn of time it seems...
As stugray says, the conventional gearbox does not care.
Put it in whatever gear you want at any time
accelerate in 1st, shift to 2nd, then plot it into 5th and cruise
you can go from 6th to 1st when slowing down.. it wont care, so long as your speed is appropriate for the gear and you match the revs
The Following User Says Thank You to 7thgear For This Useful Post:
Old 10-07-2014, 09:18 PM   #8
fatalelement
If it doesn't let you skip gears, congratulations, when did you become an F1 driver??
:P
Old 10-07-2014, 09:21 PM   #9
apexifd
Drives: 2015 FRS RS 1.0
I used to do a 1st, 3rd, and 5th upshift and skip 2nd and 4th with my FD3S. but when downshifting it really depends on what speed and how quickly do I need to slow down.
Generally, downshifting before entering a turn, it's always 5-4-3-2, and I rarely shift into 1st unless I am dead slow or completely stop.
In the regular city driving, it really just downshift to match speed for the rpm, and I usually aim for 3k-3.5k.
I am still getting use to the FRS 6 speed as the car has close gear ratio comparing to all the other 5 speed tranny that I have been driven.
Practice heel/toe or double clutch!!
apexifd is offline   Reply With Quote
Old 10-07-2014, 09:59 PM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
see I just stay in whatever gear I'm in while braking... then shift into whatever gear I need for exit before I finish my braking
I don't understand why people go 5-4-3-2
the engine braking in production cars is negligible
Old 10-07-2014, 10:02 PM   #11
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
I go:
old, correct gear ---> new, correct gear.
pushrod is offline   Reply With Quote
Old 10-07-2014, 10:02 PM   #12
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
And brake pads are cheaper than clutches.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 10-07-2014, 10:03 PM   #13
pushrod
Benched 86lb
pushrod's Avatar
Engine braking with RWD is a great way to spin the car on snow or ice.
Old 10-07-2014, 10:04 PM   #14
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
It's best to downshift so that you're always in an appropriate gear to accelerate. If someone is about to smash into you from behind you can abandon your turn and accelerate to avoid the collision.
- AdrianG
AdrianG is offline   Reply With Quote
Questions about shifting in a manual Drakelee117 BRZ First-Gen (2012+) — General Topics 63 09-11-2014 07:02 PM
New to manual driving, shifting isn't that smooth Vincenttam Other Vehicles & General Automotive Discussions 11 07-23-2014 02:58 AM
Shifting with a manual... Jen Scion FR-S / Toyota 86 GT86 General Forum 110 04-22-2014 10:46 PM
A Week of A/T Manual Shifting Mode Ocala FR-S Scion FR-S / Toyota 86 GT86 General Forum 98 05-15-2013 02:35 AM
Gearknob turning during quick shifting. Vic_RSA AFRICA 13 11-16-2012 12:48 PM
