Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 11-16-2012, 03:29 AM   #1
Vic_RSA
The voice of reason...
Vic_RSA's Avatar
Drives: 2012 Toyota 86 6MT Standard
Question Gearknob turning during quick shifting.
Hi Everyone
Not sure if I got the Friday/Monday car but has anyone else noticed their gearknob turn when the gearleaver is used aggressively?
Has anyone got the TRD Knob?
I expect this behaviour from my old Mini but not my new 86? My old Corolla RXI also did not have this issue...
Vic_RSA is offline   Reply With Quote
Old 11-16-2012, 03:38 AM   #2
LeavingNormal
FRS2DTH
LeavingNormal's Avatar
Drives: Hot Lava 2013 Scion FRS
Just get some lock tite, mine does it too. But I'm eventually going to swap out my shifter so I don't want to make it hard to removed. But that's what I did on my old car.
LeavingNormal is offline   Reply With Quote
Old 11-16-2012, 04:43 AM   #3
Crewzern
Crewzern's Avatar
Drives: 86
I have the trd gear knob ... no turning while changing gears ... i just made sure i tighten the knob as far a possible which lines up perfectly with the numbers on the knob.
Crewzern is offline   Reply With Quote
Old 11-16-2012, 04:48 AM   #4
brian_c_m
brian_c_m's Avatar
Drives: Toyota 86 - Silver High Spec
Also have a loose gearknob. Doesn't bother me too much though.
^^ I agree. Some locktite should solve the problem
brian_c_m is offline   Reply With Quote
Old 11-16-2012, 07:06 AM   #5
Gp1666
Gp1666's Avatar
Drives: Toyota 86 std Dark Grey metallic
it turns if i put effort in turning it ~ otherwise no issues when shifting ~
Gp1666 is offline   Reply With Quote
Old 11-16-2012, 07:07 AM   #6
Gp1666
Gp1666's Avatar
btw, wat mini do u have vic ?
Old 11-16-2012, 07:15 AM   #7
Vic_RSA
Vic_RSA's Avatar
I have 2x 1275E Mini Clubman's... (Clubmen?)
One is stock with low original mileage and is quite immaculate while the other is not so stock or immaculate at all but packs a 1320cc with a 60" overbore with high compression pistons. It also has the Mini GTS close ratio gearbox and an LCB exhaust with a 50mm straight though pipe. It's a real gymkhana weapon when the brakes are working.
And just in case anybody asks (as they always do), neither are for sale...
Old 11-16-2012, 07:41 AM   #8
RueFT86
Drives: Toyota FT86
Vic can you hook me up with a good mechanic for the minis. I also have a 1275 E but the car is standing for two years now without being started etc. Need to sort out the engine, wiring and paint work. Let me know urgently. Need to sort it out this December if possible. I'll really appreciate it.
Send me pics of your babies to aallijan@transunion.co.za. Cool
RueFT86 is offline   Reply With Quote
Old 11-16-2012, 08:11 AM   #9
gmookher
eventually turning knob will break it and top cap will pop off
I got wc lathe works polymer teardrop and problem fixed, sell the knob on ebay
gmookher is offline   Reply With Quote
Old 11-16-2012, 08:30 AM   #10
v3rgil
Drives: Toyota 86 Black (Standard)
same here, i must want to turn it before it turns
v3rgil is offline   Reply With Quote
Old 11-16-2012, 08:39 AM   #11
whaap
whaap's Avatar
If you use the blue lok-tite it should do the job and if and when you wanted to remove the knob you would still be able to.
whaap is offline   Reply With Quote
Old 11-16-2012, 08:42 AM   #12
Vic_RSA
Vic_RSA's Avatar
Maybe my girlfriend will buy me the TRD knob for Christmas. :P
Old 11-16-2012, 08:43 AM   #13
Guillaume
Guillaume's Avatar
Drives: Exige S 240
I screwed the knob another full 360° compared to stock. My knob is now nice and firm, quoting what she said.
Old 11-16-2012, 12:48 PM   #14
Vic_RSA
Vic_RSA's Avatar
Thanks Guillaume, it seems to have done the trick for me aswell.
Noise when turning steering wheel at low speed Slant Issues | Warranty | Recalls / TSB 7 11-06-2015 08:53 AM
Turning the Scion FR-S into an authentic GT86 TRD Kotaku91x Scion FR-S / Toyota 86 GT86 General Forum 27 02-22-2013 08:23 PM
***FR-S/BRZ LED Turn Signals (6K WHITE/AMBER FOR TURNING, NO HYPER FLASHING!)*** Vicious LED Exterior Parts - The Rest 7 11-02-2012 10:05 AM
Here's a weird one...noise hours after turning off sa1126 Issues | Warranty | Recalls / TSB 12 10-12-2012 03:15 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
