Old 09-16-2014, 07:17 PM   #1
hahaman86
Drives: 2013 Scion FR-S 10 Series #2013
Air conditioning gets warm when rpms go up
I've noticed lately in my 13 frs 10 series, when I have the ac on and cold air is blowing out of it, that if I go from stop to accelerating and my rpms go higher than 3k-4k the air gets warm. Has anyone else had this issue? Every other car I've owned it's usually the opposite effect where when the rpms go up the air gets cooler.
hahaman86 is offline   Reply With Quote
Old 09-16-2014, 07:24 PM   #2
husker741
Are you recirculating the air or having fresh air come in?
husker741 is offline   Reply With Quote
Old 09-16-2014, 07:37 PM   #3
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
Is your car blowing cold before this happens?
Old 09-16-2014, 07:40 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
I thought I read somewhere on these forums that our AC compressor shuts off temporarily when the engine is under heavy load so as not to rob it of power when it is needed most.
The Following 5 Users Say Thank You to Foobar For This Useful Post:
humfrz (09-17-2014), HunterGreene (09-17-2014), JohnJuan (09-17-2014), KGFRS86 (09-16-2014), Teseo (10-09-2014)
Old 09-16-2014, 09:56 PM   #5
SCharged
Drives: asphalt fr-s
Originally Posted by Foobar View Post
I thought I read somewhere on these forums that our AC condenser shuts off temporarily when the engine is under heavy load so as not to rob it of power when it is needed most.
If you're light on the throttle, it should make no difference.. If you're more than 80% throttle (I think it's 80%), the AC compressor shuts off to free power.
SCharged is offline   Reply With Quote
Old 09-16-2014, 09:57 PM   #6
jdmblood
jdmblood's Avatar
Drives: white subaru brz
I notice my ac gets warm after around 110 mph
jdmblood is offline   Reply With Quote
Old 09-16-2014, 11:06 PM   #7
nor cal frs
nor cal frs's Avatar
Drives: whiteout scion frs
Welcome to a four cylinder
nor cal frs is offline   Reply With Quote
Old 09-17-2014, 01:32 AM   #8
Poodles
Drives: 2015 Series.Blue
Yep, plus the high speeds tend to wear the compressors out early.
Nope, they've been doing this for years on many different cars. Most notably on Fords, even the V8's.
Old 09-17-2014, 01:41 AM   #9
hahaman86
Yeah the air is cold before this happens and I am recirculating the air. I hope it's what everyone's saying about the condenser shutting off. I have noticed it happens when I'm flooring it. I wonder if it says anything about it anywhere? I've Google searched it and read the manual but nothing about the condenser.
Old 09-17-2014, 07:24 AM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
All modern A/C compressors turn off at high RPMs/high engine load (close to WOT) to protect itself.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
HunterGreene (09-17-2014), lucid215 (09-18-2014), Teseo (10-09-2014)
Old 09-17-2014, 09:04 AM   #11
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Just go get your AC checked.... should be under warranty. DIY is easy too just to check pressure.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-17-2014, 09:07 AM   #12
HunterGreene
Hail Magnet
HunterGreene's Avatar
OP's A/C isn't broken. I am willing to bet that the cold air comes back as soon as he/she lifts off the throttle.
It has priests in it?
Old 09-17-2014, 10:13 AM   #13
aznatama
aznatama's Avatar
Still good to check just in case. Takes 5 min. At least you can definitively rule out that error.
'14 BRZ LTD MT DGM
Old 09-17-2014, 01:00 PM   #14
hahaman86
I'm under warranty so I'm just going to take it to the dealer and have them look at it might as well get my car cleaned while I'm there thank you all for the fast responses I love this forum
Air Conditioning Problems Shark Issues | Warranty | Recalls / TSB 29 10-02-2024 04:03 PM
Delete of Air Conditioning 000 Racing Engine, Exhaust, Transmission 27 07-03-2016 10:26 PM
Air conditioning squeak (and warranty coverage help) SubieNate Issues | Warranty | Recalls / TSB 9 04-16-2014 10:19 AM
Air conditioning Moldy smelling njccmd2002 Issues | Warranty | Recalls / TSB 15 05-12-2013 09:34 AM
WTB: Air Conditioning Condenser - Drats! cobrabyte Miscellaneous 3 03-20-2013 08:29 PM
