Drives: 2012 86GTS Race Car #86
Delete of Air Conditioning
So does anyone know of something to take the place of the deleted A/C Unit? Once I remove it the belt will be out of pattern... the car is a full track car so all under dash items will be removed also.. Suggestions or products please
Drives: Slowly
Supercharger?
Ummmmmm... that would be one option... I forgot the obvious.. I have to play nicely in the playground.. I have been warned that they are going over my car with a ruler !!!
Might have to make a new bracket from billet with a quality bearing and tensioner or adjuster.. trying to avoid that cost !! |
Drives: Slowly
Walkin' on sunshine
Drives: Ford BA MKII XR6 ute
Japan has the RS version with no air con so you'd think there would be a factory part that does it for you. How you go about finding that part I have no idea though.
Gutsy question. You're a shark. Sharks are winners, and they don't look back because they have no necks. Necks are for sheep.
Drives: Black 2013 FRS
get a piece of string and tie around the rest of the pulleys and see if you can just use a shorter belt. If you can, count the number of ribs and go to your local napa / autozone/whatever and get a belt that's the right length. You might have to buy a couple to get one that plays nice with the tensioner as you don't want it fully extended or retracted.
Problem, by removing the A/C pulley I am out on the routing by ribbed to non ribbed sections of the belt ??
So it's been a while and I hope someone knows more about the AC delete.. I just need to keep the belt in pattern.. I ran it for a little while the other day and the AC compressor whilst disconnected and blanked off felt hot.. it's a potential problem and weight I just dont need.
Any pics or seller of this item would be great ... I am in the States (CA) on 6 December and hope to take home any race bits !!! ![]() Thanks for looking ... all suggestions welcome |
That Guy
Drives: 2013 asphalt FRS MT
You're gonna have to import the part. Overnight it from Japan so to speak. I'd talk to AVO honestly. This isn't something they stock, but they have offices in both the US and Japan and they seem like a decent group of guys.
#10 |
AVO ?? Thanks for that.. any web address etc which would help..
Thanks and I think the Japan market is the place.. CR |
#11 |
I Love custom Turbo kits
Drives: Limited BRZ
Email japanparts.com they can get parts even when they are not on their site. I'm sure they can get it for you.
Sent from my HTC One XL using Tapatalk 2
#12 | |
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Anytime someone wants to AC delete I really want to check out their brz/frs build and see what goodies they have
#13 |
#14 |
did you ever figure this out?
