Old 09-09-2014, 10:08 PM   #1
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Squeaks when shifting gears/happens every 15 or so seconds while holding speed
Just want to know if I'm the only one experiencing this. Whenever I upshift or downshift from a somewhat slow speed, I hear a somewhat of a squeak that seems to be coming from the engine bay (not pedal) a couple of seconds after. And when I hold a certain speed, it seems to happen by intervals. Sounds like it's coming from the fuel pump, but nothing like the idle crickets... Any ideas ?
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 09-10-2014, 11:21 AM   #2
Imrac
Drives: 13 SWP BRZ Prem
It's your AC compressor. Turn off your AC or defrost and see if it goes away. (This car has a squeaky AC compressor clutch)
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 09-10-2014, 02:14 PM   #3
Simon99
Simon99's Avatar
That is smart and might be what's causing it ! Thanks I'll test that tonight !
Old 09-11-2014, 10:42 PM   #4
Simon99
Simon99's Avatar
So after checking turns out that's not what's causing the issue ...
Old 09-11-2014, 11:42 PM   #5
Mikem53
Drives: FR-S 6MT
My seat will make noise when I shift sometimes. Another owner has the same issue..
Temp affects it too.. That's the noise I get sometimes..
Mikem53 is offline   Reply With Quote
Old 09-12-2014, 08:29 AM   #6
Imrac
Old 09-14-2014, 01:34 AM   #7
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
these exact symptoms happened to me tonight on the way home. had the heat on low, fan on 2 notches, no A/C. eventually, while trying to figure out what it was, I turned the climate control off completely and the squeaking stopped.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 09-18-2014, 04:44 PM   #8
USN.Spence
Drives: 2013 Galaxy Blue BRZ
I'm having a similar issue! It's super annoying!! Low speed shifting, almost as if when the weight shifts on the rear suspension and it compresses and decompresses- however I don't believe it is my suspension as it would happen every time I hit a bump. It sounds like it is coming from the rear of the car, definitely on the drivers side. I double checked my N1 install and made sure it wasn't that squeaking, and it isn't.
I'm completely stumped, and it is driving me insane, and I was about to start a thread about this.
Edit: I hardly ever use my heat/ac, so I know that it is not related.
USN.Spence is offline   Reply With Quote
Old 09-18-2014, 04:52 PM   #9
Simon99
Simon99's Avatar
Same here but I feel like the noise is coming from the front
Old 09-18-2014, 04:59 PM   #10
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You just keep running over mice. If you shift at 6000rpm or higher, you won't hear them dying.
Old 10-11-2014, 03:54 PM   #11
USN.Spence
Hey guys, I took my car to the dealer and they couldn't identify where the squeak was coming from, so they torques my suspension to factory settings, and the squeak is gone!
Automatic Transmission Kick/Choke when shifting gears Tech Gremlin Engine, Exhaust, Transmission 13 06-16-2015 01:54 AM
Speed in gears calculator glamcem Tracking / Autocross / HPDE / Drifting 8 07-17-2014 02:19 AM
AFR leaning out after shifting gears Toyota John Software Tuning 14 05-23-2014 01:05 AM
Clunking gears when shifting? hmkk Issues | Warranty | Recalls / TSB 4 02-19-2014 06:14 PM
