Old 07-15-2014, 02:52 PM   #1
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Wink Speed in gears calculator
Sorry if it's repost...
A friend of mine gave me this link a while ago and I figured you might be interested to use it as well.. I find it quite beneficial to study the correct gearing/speeds for certain corners especially after adding the SC, you may also see the effects of the different size of tires, final gear ratios and whatnot and unlike other calculators this one allows you to pick the car from the dropdown menu with predefined settings ( you might need to modify for the AT FRS/BRZ)..I think overall it's a good way the analyze shifting at track especially if you compare that to your track logs (I noticed I upshifted at many places unintentionally) ..
http://www.precisionsite.com/auto-x/tools/
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
DAEMANO (07-15-2014)
Old 07-15-2014, 02:58 PM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
now if only there was a metric conversion so that everyone else in the world could use this without busting out a calculator
otherwise great tool
if you plug in the values for the Cusco Final Drive you can see the drastic effect it has on the overall spread.
also, I don't gain too much gearing with an 245/40/18 vs a 225/40/17 ... hoped it would be more.
The Following User Says Thank You to 7thgear For This Useful Post:
glamcem (07-15-2014)
Old 07-15-2014, 03:22 PM   #3
I use this one
http://www.turnzero.com/technical_re...ear_calculator
It graphs it out for you so you can see the RPM in the next gear
It also conveniently has S2000 gearing stored....
Old 07-15-2014, 03:58 PM   #4
CSG David
CSG David's Avatar
I have a complete spreadsheet of stock gearing for MT and AT along with different final drives and gear sets to identify what can be done.
Old 07-15-2014, 04:10 PM   #5
glamcem
glamcem's Avatar
I use this one
it looks good then again it would be really good if they had a bigger selection of cars for that reason I just look at the values horizontally to see the corresponding rev in the upper gear, in the tools that I posted
that makes sense, maybe that's what I need to do or maybe I can put a formula with a macro in a spreadsheet so it draws the graph as well but I am lazy
Old 07-16-2014, 11:04 AM   #6
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Note that if you want accurate results, you'll need a calculator that lets you enter your own tire circumference, and that you'll need to measure tire roll out to get that number.
dradernh is offline   Reply With Quote
Old 07-16-2014, 11:30 AM   #7
s2d4
s2d4's Avatar
KM/H
http://www.teammfactory.com/gearcalc...ission+1+%26+2
MPH
Very good calculator, graphs, point to the line to check the speed at which rpm.
Left is MT and right is AT.
The Following User Says Thank You to s2d4 For This Useful Post:
glamcem (07-16-2014)
Old 07-16-2014, 09:18 PM   #8
glamcem
glamcem's Avatar
Originally Posted by s2d4 View Post
KM/H
MPH
Looks good but again our cars are not listed in the list
Old 07-17-2014, 02:19 AM   #9
s2d4
s2d4's Avatar
True. It is already setup to work by clicking the link though.
Anybody change rear gears or trans gears yet? ramosryan Scion FR-S / Toyota 86 GT86 General Forum 2 06-13-2014 12:48 AM
0-60 calculator Barbarian Off-Topic Lounge [WARNING: NO POLITICS] 13 05-01-2014 06:18 AM
RPM calculator with drag coefficient? mike_ekim1024 Engine, Exhaust, Transmission 7 11-11-2013 08:07 AM
FR-S Speed/RPM Calculator FR-S #2637 Engine, Exhaust, Transmission 8 09-19-2012 11:41 AM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
