Old 08-28-2014, 07:23 PM   #1
BRZ'13
BRZ'13's Avatar
Drives: subaru
BRZ'13 is offline   Reply With Quote
Old 08-29-2014, 10:07 AM   #2
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
Originally Posted by BRZ'13 View Post
Tried searching but could not finding anything. I am having a weird problem with my BC BR coilovers, specifically the rears. One side is completely maxed out because the threads cannot spin into the shock body any further. The other side still has 1.5"+ of low but when measuring from fender to ground on a flat surface they are both 25" from the ground. The fronts are 24.5" each and i would like the rears to be 25.75" but the one side cannot go lower.
Im thinking it has something to do with the preload but i dont see how that has anything to do with height
Could it be that your not on completely even ground? I wouldnt measure from the coilover to the ground i would just set both rear coils to the same hight, put it on the ground and go from there. If one sides sitting lower or higher then adjust that side. Right?
And yes preload has nothing to do with it, set the preload and dont touch that again.
-Dave
DavidBob is offline   Reply With Quote
Old 08-29-2014, 02:35 PM   #3
cnk
Drives: '13 DGM BRZ Limited
Don't measure from fender to ground as tire pressure/wear can throw off the measurement. Best to measure from fender to center of hub.
Sent from my SAMSUNG-SM-N900A using Tapatalk
cnk is offline   Reply With Quote
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 12:09 PM
WTB: Ksport Control Pro Coilovers or BC Racing Extreme Low Coilovers ProjectBrz Brakes, Suspension, Chassis 1 04-15-2014 12:21 AM
* BC Racing BR Coilovers & Stance Super Sport Coilovers | IN STOCK | FAST SHIPPING * Speed Element Brakes, Suspension, Chassis 21 03-03-2014 08:56 PM
Issue with BC BR extreme low coilovers 86TruenoFRS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 08-17-2013 09:27 AM
Stance coilovers lowering issue Dispect Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 08-06-2013 11:05 PM
