Old 08-23-2014, 06:26 AM   #1
JamesBond000
First Class Speeder
Drives: Silent and Quick
Anyone have Issue With Under Shield? Unsure on name
The cardboard like shielding thats on most of bottom of the frs mine ripped off where the screw bolts were and ripped in half on freeway i noticed there was a runoff valve that was leaking onto it the whole time >.>
JamesBond000 is offline   Reply With Quote
Old 08-23-2014, 10:02 AM   #2
Malt
Drives: 2015 WRX
Runoff valve? What type of fluid is leaking? Are you referring to the drain line for the air conditioning? I would highly doubt that the AC drain would cause an issue like you experienced and its more likely you either:
A: hit something while driving at some point which tore some of the mounting holes.
B: If you removed it to install mods you may have over tightened the bolts that hold it on, which cause the bolts to rip through the holes thereby weakening the aero panel.
C: A service shop or yourself left some bolts off when putting it back on.
Excessive freeway speeds with a combination of any of the above could caused the failure. That panel sees water every single time you drive in the rain and it's not going to fail without something helping it along.
Malt is offline   Reply With Quote
Old 08-27-2014, 04:12 AM   #3
JamesBond000
First Class Speeder
LOL... The AC drain was facing over the cover instead of off to the side. I put it back on normal did not appear to overtighten but i did have a accident on freeway when a truck shat out shrapnel of metal and it did hit that area lightly last month. So nothing out of the norm it did its job for as long as it could :P took it off it was like 2 x 2 feet in size.
Case Closed :P
Racer X Fabrication heat shield, help us to help you Jeff@Racer X Fab Engine, Exhaust, Transmission 31 07-17-2014 09:20 AM
[WTB] transmission under shield Fizz Australia Classifieds 0 10-01-2013 01:19 AM
Anyone spray their front splash shield? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 2 08-20-2013 06:44 PM
Sound shield over fuel pump? Pacific Auto Engine, Exhaust, Transmission 1 08-20-2013 04:27 AM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
