Old 08-20-2013, 12:25 AM   #1
Pacific Auto
Master Installer
Pacific Auto's Avatar
Drives: Scion FRS
Sound shield over fuel pump?
Is that just a sound shield covering the high pressure fuel pump to reduce the crickets?
I took it off when I was diagnosing the sound awhile ago. Thing is darn heavy and is insulated with foam.
I doubt its for heat since its on top?
If so doesn't that prove toyota/subaru knew of the problem before hand?
Possible good weight saving!
Pacific Auto is offline   Reply With Quote
Old 08-20-2013, 04:27 AM   #2
FRSRAVEN
Except when you remove it, your car will sound like a swarm of locusts as it drives by. My sanity is not worth a pound of weight savings.
And Toyota knew that all high pressure fuel pumps make noise. Nature of the beast.
FRSRAVEN is offline   Reply With Quote
Why does the fuel pump not do well with ethanol? boredom.is.me Engine, Exhaust, Transmission 42 02-28-2019 06:21 PM
2013 FRS fuel pump sound MosesFRS Issues | Warranty | Recalls / TSB 9 02-23-2013 09:01 AM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
