Old 08-18-2014, 04:10 PM   #1
Cross
It's the Mad Cow
Cross's Avatar
STi Clutch Disc on FRS/BRZ?
I thought the new STi had a version of the FA20 boosted. Would using that clutch disc be an option considering it's meant to take more power?
Since I have boosted I keep asking myself when the stock clutch is not going to be able to hold. I have thought a few times I felt the clutch spinning so I figured when I have the motor out this would be the time to upgrade and lighten the flywheel.
I did a quick search and didn't find anything so I apologize if I missed it.
Thanks
Old 08-18-2014, 04:20 PM   #2
Scottemad123
Drives: 2014 SWP BRZ Limited
Thanks
STI for 2015 is still using an EJ, for now just the WRX has a boosted FA20 but different than ours on a few things.
Scottemad123 is offline   Reply With Quote
Old 08-18-2014, 04:22 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Thanks
How high do you plan to go on power, being very honest?
If staying under 350 wtq, Exedy stage 2 is a dream come true.
Old 08-18-2014, 04:33 PM   #4
Cross
It's the Mad Cow
Cross's Avatar
I will not be upping the boost any further but then I did already fail once even if it was a fluke it's hard to shake.
I am below 400 or right at it on E85 and 16psi, that's the max for the car it's not getting any more.
SOLD!!! EXEDY TWIN DISC Clutch Kit Sportsguy83 Transmission and Driveline 27 10-04-2014 09:06 AM
Replace entire OEM clutch assembly, or disc? radroach Engine, Exhaust, Transmission 8 08-07-2014 11:00 PM
Anyone tested Cusco Single Copper Clutch Disc? Hempo Engine, Exhaust, Transmission 4 05-08-2014 07:13 PM
Stock clutch disc and pressure plate. $175 shipped. conekiller Transmission and Driveline 4 02-21-2014 10:31 AM
Assembly Paste for Disc Brakes . . . ? Marrk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-04-2013 12:02 AM
