Old 08-06-2014, 02:01 AM   #1
radroach
Drives: car
Replace entire OEM clutch assembly, or disc?
So my clutch has been soft lately, 39k miles. Thinking of replacing it- do I need to buy the whole clutch assembly or can I just replace the disk?
Old 08-06-2014, 08:09 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Is it slipping? More than likely you can just replace the friction disk but if pedal feel has gone soft you may just need to bleed the clutch fluid.
1974 TA22 Celica
2013 86 GT
Old 08-06-2014, 11:40 PM   #3
Poodles
Drives: 2015 Series.Blue
If it needs a clutch, you replace the disk, pressure plate, and throw out bearing at the least. Flywheel needs to be replaced or machined.
This.
I doubt it needs to be replaced at that mileage. Depends a lot on what you mean by "soft" as clutches take a while to break in correctly and once they do, they're not as grabby.
Old 08-07-2014, 12:51 AM   #4
radroach
Drives: car
I have plenty of pedal feel, it's just that the car doesn't take off at low rpm's like it used to. Sometimes it seems to muddle around when I'm starting in 1st, grips, and then lets me take off slowly. No longer catches well at low rpm, I should say.
Old 08-07-2014, 02:10 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
Do the revs flair? Or does the car just feel slow to take off?
1974 TA22 Celica
2013 86 GT
Old 08-07-2014, 04:15 AM   #6
Poodles
Doubt it's the clutch in this case as if it was actually slipping, it would slip much worse at the torque peak in the powerband.
Old 08-07-2014, 09:31 AM   #7
radroach
Drives: car
Slow at take off. Similar to how the TC might bog you down if you slip the clutch the wrong way? Perhaps that's what's going on.
I can just tell the clutch doesn't feel as good, I can hear it more, and it doesn't let me take off as well as I used to.
Since my clutch bearing is also worn, I might just replace the whole assembly.
Old 08-07-2014, 07:44 PM   #8
Turdinator
Señor Member
Turdinator's Avatar
I can't imagine how the car bogging down could be clutch related. Also how do you know your clutch bearing needs replacement?
1974 TA22 Celica
2013 86 GT
Old 08-07-2014, 11:00 PM   #9
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Are you running stock power/GQ. Any boost?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
SOLD!!! EXEDY TWIN DISC Clutch Kit Sportsguy83 Transmission and Driveline 27 10-04-2014 09:06 AM
Anyone tested Cusco Single Copper Clutch Disc? Hempo Engine, Exhaust, Transmission 4 05-08-2014 07:13 PM
Stock clutch disc and pressure plate. $175 shipped. conekiller Transmission and Driveline 4 02-21-2014 10:31 AM
OEM Clutch Replace time JRollar Engine, Exhaust, Transmission 18 06-19-2013 12:25 AM
Assembly Paste for Disc Brakes . . . ? Marrk Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-04-2013 12:02 AM
