Old 08-03-2014, 10:52 AM   #1
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Greddy Magnatic Oil Plug with OEM Washer
hello everyone. when i did my oil change, i changed my oem oil bolt to Greddy one and used washer that came with. i am going to do my next oil change soon and wondering using OEM washer is fine with Greddy bolt.
I am trying to avoid possible leak here. anyone with Greddy oil bolt, little help?
Old 08-03-2014, 10:57 AM   #2
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Should have no issue
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
zc06_kisstherain (08-03-2014)
Old 08-03-2014, 05:41 PM   #3
JB86'd
JB86'd's Avatar
Drives: JAWS
I use an OEM washer with the Greddy magnetic bolt. Holding fine so far
The Following User Says Thank You to JB86'd For This Useful Post:
Old 08-03-2014, 07:13 PM   #4
zc06_kisstherain
Drives: SWP BRZ
Thanks. I heard someone had issue with oem one. I just wanted make sure.
Old 08-04-2014, 03:26 PM   #5
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
I use the OEM one as well. No issues to report
fantah is offline   Reply With Quote
The Following User Says Thank You to fantah For This Useful Post:
zc06_kisstherain (08-06-2014)
Old 08-04-2014, 03:57 PM   #6
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Mine leaked with the one the plug came with, its been fine with oem washers
Jrdad is offline   Reply With Quote
The Following 2 Users Say Thank You to Jrdad For This Useful Post:
brz408 (08-10-2014), zc06_kisstherain (08-06-2014)
Old 08-06-2014, 10:25 AM   #7
zc06_kisstherain
Drives: SWP BRZ
Good to hear!
thanks
Old 08-15-2014, 02:40 PM   #8
zc06_kisstherain
Drives: SWP BRZ
little late but i changed my oil last saturday
because of that magnetic bolt, when i unbolt, it stuck at pan!!! and oil splashed to group not to oil drain container! haha.
anyway, there is no weak as metnioned after changing oil.
Greddy Oil Drain Plug - Leaking Pokeguyjai Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 03-28-2026 09:56 AM
Beware || oil drain plug washer (when changing your oil) mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 11-14-2021 06:07 PM
Washer for oil drain plug missing? Kind of urgent. qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-07-2014 01:43 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 10:19 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 11:28 AM
