Old 08-01-2014, 12:03 PM   #1
MurderRider
MurderRider's Avatar
Drives: 2015 Raven FR-S 6MT
Does OFT raise rev limiter?
I'd like to be able to hit 60 instead of 58 in 2nd gear. Does OFT make this possible? Anyone run a good 0-60 in just 1st and 2nd gears with with a rev limiter raised due to a tune?
MurderRider is offline   Reply With Quote
Old 08-01-2014, 12:09 PM   #2
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Definitely possible, I know a few autocross guys who are running 7800 or 7900 for just that reason. Not sure if OFT has rev limit per gear though.
Decay107 is offline   Reply With Quote
Old 08-01-2014, 12:16 PM   #3
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
We do raise the rev limit to 7600rpm in all our OTS maps (for 6MT cars). To be honest, I'm not sure what MPH it translates to in 2nd gear but I'm pretty sure it's over 60.
Shiv@Openflash is offline   Reply With Quote
Old 08-01-2014, 12:32 PM   #4
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
Tire diameter (in.): 24.62
RPM: 7600
1st Gear Ratio: 3.626
2nd Gear Ratio: 2.188
3rd Gear Ratio: 1.541
4th Gear Ratio: 1.213
5th Gear Ratio: 1.000
6th Gear Ratio: 0.767
Final Drive Ratio: 4.100
1st Gear (mph): 37
2nd Gear (mph): 62
3rd Gear (mph): 88
4th Gear (mph): 112
5th Gear (mph): 136
6th Gear (mph): 170
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 08-01-2014, 12:46 PM   #5
MurderRider
That's awesome. So I'm assuming that allows for around a 6 second time? Getting closer to buying this thing...
Old 08-01-2014, 12:53 PM   #6
edeekeos
edeekeos's Avatar
The OFT is WELL 'worth it's weight in gold'. Best purchase I have ever made for a vehicle as far as power/cost goes. Not only does it unleash quite a bit of hidden power, it immensely smooths out the overall feel of the engine, not to mention being able to run e85. Also, you have full data monitoring/logging capabilities, and being able to input that info into VirtualDyno in kinda kool. I was on the fence for a while, but I am so glad I sprung for it.
Old 08-01-2014, 12:58 PM   #7
mid_life_crisis
Drives: FR-S 10 #103 AT
I'm assuming you don't raise the limit on the automatics because there is slippage or something?
Another question that I've asked elsewhere and not had answered, on the subject of rev limits, is: why did the automatics not get the new soft rev limit setup? We can and frequently do drive in full manual mode.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-01-2014, 04:06 PM   #8
KonTheory
Drives: '14 FRS
I dunno if this helps your decision..
but I had my car dyno'd with the 1.59 map
All I have is a nameless axleback and a drop in air filter
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
KonTheory is offline   Reply With Quote
Old 08-01-2014, 04:12 PM   #9
Shiv@Openflash
Drives: 2013 FRS
With 6AT, max rev limit is effectively controlled by the TCU (transmission control unit) not ECU (which is what we flash). So even if we raised the max rev limit values in the ECU flash, the TCU would still shift at the same RPM. It may be possible, in the future, to flash the TCU but that is a big IF. Nothing we have looked into yet. I don't think that has even been done before outside of Toyota.
Cheers
shiv
Old 08-01-2014, 04:13 PM   #10
Shiv@Openflash
Drives: 2013 FRS
Nice! Do you know what a stock FRS puts down on that Dyno Dynamics dyno?
Old 08-01-2014, 04:14 PM   #11
KonTheory
Drives: '14 FRS
I was hoping Id have time to uninstall and run again but it didnt happen, so unfortunately I do not...
But I was hoping for exactly what I got so I was very pleased with this
Old 08-01-2014, 04:16 PM   #12
gramicci101
Off Topic
RPM: 7600
1st Gear (mph): 37
2nd Gear (mph): 62
3rd Gear (mph): 88
4th Gear (mph): 112
5th Gear (mph): 136
6th Gear (mph): 170
Sweet! This way I only need 3rd gear to activate the flux capacitor and go back in time!
Old 08-01-2014, 04:28 PM   #13
mid_life_crisis
Cheers
shiv
Full manual? It doesn't shift at all. It bounces off the rev limiter and drops down to about 7000 rpm. At that rpm I would hope the torque converter is in full lockup, so there shouldn't be any slippage. I see no reason the rev limit can't be higher for 6AT.
And this still doesn't explain why the 6AT didn't get the soft rev limiter like the 6MT did.
Old 08-01-2014, 04:33 PM   #14
Shiv@Openflash
Drives: 2013 FRS
It can certainly be implemented just by copying the ignition A and ignition B tables (and rev limit values) over from the 6MT map. But to be honest, I don't usually do things like that on Auto cars. Sometimes applying soft rev limits can have an impact on shifting performance when in automatic mode.
Coilover to Raise Ride Height Furtive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 07-28-2014 12:57 PM
Raise or stay? Bongertz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 07-16-2014 04:12 AM
Raise or stay? Bongertz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-03-2014 12:57 AM
Raise Suspension for Winter? Foobar Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 10-25-2012 03:20 PM
Raise BRZ djenriquez07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 08-14-2012 01:28 PM
