Old 07-17-2014, 09:01 PM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Hood Venting, NACA Ducts
I just ordered two Naca ducts or vents in my case to put in my hood. I want to suck the hot air out.
Question, where should they go? Front of the hood, middle, or back.
I am thinking right over the alternator and power steering pump. I'm trying to copy the efect of the hood on my Minibusa (pictured).
Lunatic is offline   Reply With Quote
The Following 2 Users Say Thank You to Lunatic For This Useful Post:
extrashaky (07-18-2014), glamcem (07-29-2014)
Old 07-17-2014, 09:37 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
There has been some discussion about hood vents in this thread (mostly for FI applications, but some applicable to NA)
http://www.ft86club.com/forums/showthread.php?t=53580
The Following User Says Thank You to Lonewolf For This Useful Post:
schlitzed (02-06-2015)
Old 07-17-2014, 10:49 PM   #3
Lunatic
Lunatic's Avatar
Thank you, I read that entire thread last night, but didn't see anything about vent placement.
The Following User Says Thank You to Lunatic For This Useful Post:
86-tundra (07-18-2014)
Old 07-18-2014, 12:32 AM   #4
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Wow, interested to see what you are going to do here. definitely keep us updated..
86-tundra is offline   Reply With Quote
Old 07-18-2014, 12:51 AM   #5
FlamingRectumSyndrome
Shriveled Old Member
FlamingRectumSyndrome's Avatar
Drives: 14 Hot Lava FR-S
The only way to really know is by doing actual wind tunnel testing to find out whether there's a low pressure area. That's where you'd want to place an induction type duct. Without actual data, you'll be wasting your time and money.
FlamingRectumSyndrome is offline   Reply With Quote
Old 07-18-2014, 02:14 AM   #6
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by Lunatic View Post
I want to suck the hot air out... I'm trying to copy the efect of the hood on my Minibusa (pictured).
The hole in that picture doesn't look like it's intended to suck hot air out. It looks like it's designed to suck more air through the radiator to make the liquid cooling more efficient. Hot air off the engine looks like it would still well up under the hump behind the fan with nowhere to go.
As for NACA vents, I believe those are designed to suck air in, not out. They're replacements for scoops to get cool air into the intake or to route cool air to the brakes. Usually if you're venting to suck air out, you use louvered vents facing away from the direction of travel, like so:
These give you lower pressure above the hood and higher pressure below, so that the hot air sucks right up through the louvers. You usually want them high up on the hood, since hot air rises.
NACA vents have the higher pressure on the outside, ramming the air in the wrong way for what you say you want to do. And I don't think turning them around the wrong way will help.
Old 07-18-2014, 09:31 AM   #7
Lunatic
Lunatic's Avatar
Actually no hot air under my Mini hood as the engine in mounted in back, mid engine.
Maybe I'm wrong about NACA scoops. I thought they would work either way.
Old 07-18-2014, 09:46 AM   #8
Lunatic
Lunatic's Avatar
Yesterday I removed the plastic inserts from my fenders. Using my hand held cut off wheel I cut an opening in the inner fender. Took the car for a drive, got it hot, and with the engine and fans running you could really feel a lot of hot sir blowing out. The air flow was enough to blow a Bic Lighter out at 8 inches away.
I have a friend who is a carbon fiber guy and he took my inserts and is going to make me screened, vented, carbon fiber inserts. I think this should help allot for removing hot air from under the hood.
DAEMANO (07-18-2014), edeekeos (07-21-2014)
Old 07-18-2014, 09:48 AM   #9
retoocs
NACA ducts are for moving air in.
retoocs is offline   Reply With Quote
The Following 3 Users Say Thank You to retoocs For This Useful Post:
Dadhawk (07-21-2014), DAEMANO (07-18-2014), wheelhaus (07-18-2014)
Old 07-18-2014, 10:02 AM   #10
wheelhaus
wheelhaus's Avatar
Yes, NACA ducts are designed to suck air in from a flat surface that sees laminar airflow.
The slatted vents pictured above are called louvers, and are usually to let hot air escape.
The location of the inlet and outlet vents is somewhat important, can't just slap them anywhere. Need to consider high and low pressure, so an inlet vent is in an area of higher pressure, or the outlet vent is in an area of lower pressure, or both. You could have vents all over the place and surprisingly, they may not do much at all if they're not in the right areas.
wheelhaus is offline   Reply With Quote
Old 07-18-2014, 11:00 AM   #11
Lonewolf
Lonewolf's Avatar
Drives: Moped
A couple of members have done something similar to the fenders and they all commented that they could really feel the hot air pour out after a drive. Looking forward to how yours turns out...
Old 07-18-2014, 11:09 AM   #12
radroach
Drives: car
Show us a vid, I want proof!
Old 07-18-2014, 03:57 PM   #13
bama_brz
bama_brz's Avatar
Drives: '14 SWP BRZ
Really looking forward to see how this turns out.
bama_brz is offline   Reply With Quote
Old 07-18-2014, 04:47 PM   #14
Frozen_skidmark
Frozen_skidmark's Avatar
Drives: Whiteout FRS
Is heat a problem? I've had the car out in 36℃ 96.8℉ with the A/C on In traffic and never seen the needle go past the second line. Does it start climbing if you're in Texas per se?
2014 Whiteout FRS
Frozen_skidmark is offline   Reply With Quote
APR Brake Ducts msile Cosmetic Modification (Interior/Exterior/Lighting) 23 09-08-2014 02:30 PM
Brake Air Ducts kombatlion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 07-17-2014 05:39 PM
Project Mu Brake Ducts Now Available! Xero-Limit Brakes, Suspension, Chassis 1 06-11-2014 10:42 AM
My insurance story (Venting) Apex-Wolf Scion FR-S / Toyota 86 GT86 General Forum 25 03-19-2014 02:26 PM
Venting - Bad Habits BRZ First-Gen (2012+) — General Topics 25 09-19-2013 04:26 PM
